-   -   2.7 injection air injection plugs needed (http://forums.pelicanparts.com/911-engine-rebuilding-forum/282297-2-7-injection-air-injection-plugs-needed.html)
C-Pierce 05-11-2006 06:54 PM
Hi, where can I get a set of air injector plugs for my 2.7 heads? we have ejected the air injection and re built the motor. this is tha last stumbling block. can I just go 2 my local hardware supplier or is it a really specific piece.?
Chris
'76 S sunroof coupe
RoninLB 05-11-2006 11:23 PM
Pelican sells them. I used red loctite.
afterburn 549 05-22-2006 04:25 PM
also Ace hardware has hex headed plugs that will screw right in ( use high temp thread lock)
john walker's workshop 05-22-2006 07:55 PM
1/8" pipe plugs. their taper locks them in nicely. try to find hex head ones.
afterburn 549 05-22-2006 07:57 PM
Yup/lots less pricey
vanwyk4257 06-13-2006 01:20 PM
What material would be best used, brass or aluminum? I'm looking to do this on my '75 as well. Thanks!
MBruns 06-13-2006 01:39 PM
plugs
The mercedes automatic trans. pan drain plug works well, the dealers should stock plenty
Mike Bruns
vanwyk4257 06-13-2006 03:03 PM
I just ordered some hex-insert aluminum plugs from Jegs, we'll see how that goes.
afterburn 549 06-14-2006 08:05 PM
I dono why people want to spend more $$$??
