3.2 Carerra Dizzy problem
http://forums.pelicanparts.com/porsche-911-technical-forum/282276-distributor-question.html
Can anyone please help. :( |
Don't know much about that Dizzy. I'd be tempted to take it apart and try to figure it out. Turn the motor to TDC #1 befor removing the Dizzy so you can put it in right.
-Andy |
Thanks Andy... ;)
HI have you sorted the dissi' out yet, if not give me a ring i will prob' have some bits/dist to sort it out. ring 015395 67959 www.mbporsche-engineering.co.uk
regards mike |
HI i have just had a look at a spair diss' i have and it looks like a screw holds the top in and two springs on the bobweights. have a look at your bits you pulled out, the screw could be still in the shaft under the felt bush under the rotorarm.
regards mike |
Thanks for all the advice.. I'll give you a call. :)
| All times are GMT -8. The time now is 02:29 PM. |
