-   -   What to build- 3.6 N/A or 3.6 TURBO (http://forums.pelicanparts.com/911-engine-rebuilding-forum/283030-what-build-3-6-n-3-6-turbo.html)
herman maire 05-15-2006 04:12 PM
I have been thinking about this for too long and I still can not come to a decision on this matter.
I have been thinking of 2 options.
#1 N/A 993 3.6
1-STB set up (INTAKE)
2-aggresive cams (7500-7800 RPM- Red line)
3-after market EMG
4-aggresive exhaust
5-upgraded -ROD BOLTS
6- NO POWER STEERING
With this set up I would hope to expect at least 325-350HP
#2 Turbo- N/A donner 993 3.6
1- single turbo
2-JE lower comp pistons- 8.5ratio maybe 9.
3- aggresive cams (6900-7500RPM-red line)
3-after market EMG
4- upgraded rod bolts
5-NO power steering
Expected power 380-425HP . I will not be getting crazy with BOOST.
What set up would be the most rewarding??? Stronger turbo VS weaker N/A.
For some reason I am favoring the weaker N/A set up just because throttle responce + sound will ( I think) be so much better on the N/A set up also I would not have a heavy turbo hanging out back.
Then I think of the power a well set up turbo has available and the money I would save on the N/A STB set up .
MY brother and I will be building the turbo set up + the help from fellow pelican's so I will not be paying a shop for any work .
I would really apreciate any opinion's on the N/A VS TURBO
kenikh 05-15-2006 04:53 PM
A redline that high on a 3.6? Isn't that asking for trouble? I'd build the turbo; I think the motor would live longer.
herman maire 05-15-2006 05:48 PM
Really..... I would like to think that 7500RPM red line would be on the cautious side, maybe 7800RPM is pushing it, but 7500RPM... I will be very surprised.
I mean its really only 600RPM more than stock.
I am really after the most electric driving experience possible. I know that a turbo will be faster but I just feel that some of that edgy character of a N/A would be lost with a turbo.
I wish I had more experience with these 2 styles of cars.
89turbocabmike 05-15-2006 08:50 PM
Herman, turbo will definitely give you that electric feeling. You can machine down the stock mahle pistons(per henry@supertec) for the cr you want and save the JE money. With the increased displacement, CR and efi you will definitely achieve better drivability than a cis 3.3 that you've heard about/or perhaps driven that you feel isn't edgy. A quick spooling turbo will also help since all out power is not your goal. Turbo=ELECTRIC....but then again I'm a bit biased;)
dean 05-16-2006 05:03 AM
I am biased also. Go turbo. Every car I have has a turbo. I have had a turbo on at least one car I have owned since 77 save a couple sad years in the mid 80's.
So why don't you try to go for a ride in comparable cars and see which one floats your boat. Or you could just do the right thing and go TURBO:D
Steve@Rennsport 05-16-2006 10:16 AM
Hi:
You've gotten some great advice, especially from Dean,...:)
Get a ride in both kinds of cars and make the decision based on that experience and your preferences.
I happen to prefer N/A engines with really sharp, crisp throttle response that have a lot of snap. For twisty kinds of roads, its hard to beat a 3.6-3.8 with ITB's, the proper cams, and a good Engine Management system. Combined with close-ratio gears, its really neat,...:) :) :)
RarlyL8 05-16-2006 10:39 AM
Your choice dependes on what you want to do with the car, what your driving habbits are, and what exhaust sounds "do it" for you.
For example, if this is a steet car that will be driven often and taken on short trips you probably don't want a high strung N/A engine.
If the result desired is a dual-purpose street/track car that you wish to hit the back roads with and frighten children and small animals then by all means do the chainsaw N/A motor.
The difference is not so much power but how it is applied. The turbo is stealth power. You can have a quiet exhaust and a smooth idle with the same HP as a well built high-strung N/A motor.
beepbeep 05-17-2006 07:59 AM
I would opt for turbo.
First of all, highly strung N/A engine will need to spin fast, and spinning fast will wear the engine more. Also, 3.6 is a perfect base engine for turbo-conversion as it already have twin plugs and everything else.
With well-matched turbo you'll make 500+ hp w/o revving to high heavens. You will also accellerate away from even the most extreme N/A 3.6 you could possibly make (using cubic dollars).
Even if it sounds weird, turbo converted 3.6 is most bang for buck you could get, horsepower-wise. Use JE or even OEM 3.6 turbo pistons.
Swept area under power curve is what accellerates the car and turbocharged engine will accellerate faster than N/A of similar power thanx to much meatier torque down low. N/A 3.6 spinning at 7500 RPM will have lifetime of a butterfly, will cost a fortune to build and will be beaten by warmed-over 3.3 with slightly raised boost. Yes, there is a difference in engine responce but I personally wouldn't pay a premium and loose so much power just to have good throttle response.
So yes, go turbo.
BReyes 05-17-2006 10:41 AM
I would get the turbo set up. Why such a high CR? Yet, your first option also results in a proven performer on the track.
Regards,
herman maire 05-18-2006 08:26 AM
Thanks for the info guy's.
I will say that I am far from commiting to N/A or TURBO yet. I did enjoy reading everyone's case for builing a TURBO. ( Goran, Dean, Rarly I am not the least surprised heh, heh.)
I guess what I keep coming back to as a comparison is the 996 GT3 VS 996 GT2. Almost everytime it seems that the N/A GT3 gets the "nod" for the most rewarding drive even though it is underpowered and might get passed on the straights. This is what fuel's my indecison.
I am really surprised that a 3.6 would have the " lifetime of a butterfly" (Goran heh,heh funny but sad I guess). So if 7500RPM is pushing it, would 7200RPM be a happy medium??
Goran- You pointed out that if I was to go with a turbo you mentioned
JE pistons or OEM 993 turbo pistons. Would lowering the CR on my stock
pistons like Mike Mentioned ( Henry@supertec)????
If I recall IF2 had piston problem's with the N/A pistons it first ran... right?? Also what CR would you run to minimize lag??? I am thinking 8.5 or 9 to minimize lag but I know this will limit the Boost I can run.
I will be running a aftermarket EMG
I have many, many questions.
If anybody has any opinion's or experience with tuned N/A VS TURBO
please let me know.
beepbeep 05-18-2006 06:17 PM
IF2 still uses OEM 993TT pistons. It was dynoed to tripple the power you'll ever extract from N/A 3.6. It never ever had problems with pistons itself but motor was cammed to produce peak power @ 7500 RPM. As OEM 993TT pistons are quite heavy, OEM rod bolts took a beating at those revs and had to be replaced due to wear. It never used OEM N/A pistons.
For moderate power (<500hp) you could use 993TT pistons all day long as long as you don't rev beyond 6500 RPM. With matched turbos, you can make a killer motor for moderate $$$ input and drive it for a long time w/o costly rebuilds.
Or you can go the N/A route, buy unobtanium ITB's, headers, rods and pistons, rebuild it every year and still get spanked by some bloke reving 5500 and boosting 1 bar. You can always listen to the noise but noise doesn't propel the thing, it just makes your ears ring ;)
RarlyL8 05-18-2006 08:43 PM
Herman, I am not as biased to turbo power as you might think.
Re-read my post above. Truely, you must think of how YOU wish to drive the car. Some folks can handle a chainsaw motor all of the time - that is their personality. I'm too old for that now. I still like power but for the long haul my butt wants a nice idling car with an exhaust note that won't have the neighbors throwing rocks at me.
Here is what I had before the turbo. This baby ROCKED! Sounded like a mad banshee and carved up roads like a go cart. I miss that car soooooo much.
http://forums.pelicanparts.com/uploa...1148010137.jpg
Wayne 962 05-19-2006 01:01 AM
I like non-turbo cars personally, but I also like the thin-boddied early 911s too. It's really a matter of preference, although a non-turbo will undoubtedly be less expensive...
-Wayne
911teo 05-19-2006 06:09 AM
-Wayne
I don't think a 7.500 rpm N/A engine will be less expensive than a moderate boosted turbo engine...
I am building one and we are changing rods, valves, lifters, retainers etc. to obtain a decent longevity from the engine.
So I went the N/A route. I didn't need/want 500hp on a 2,500lbs car. Like Steve said above the N/A engine will have a fantastic throttle response and it will sing to you.
The big advantage of the turbo will be the torque avaliable at very low rpms (compared to the highly strung N/A engine you have in mind).
If I were driving mostly on the highway, if this was going to be my commuter car and I wanted a less "tiring" car to drive I'd go for the turbo.
Plus I think the turbo would be much cheaper to build. As you said just lower the compression ratio, get a good EMS and you are done.
Having said that would you rather drive a 73RS, or a 930? A 964 RS/993 RS or a 993TT, a 996GT3 or a 996TT.
I realize in those cars is not just the engine that is different but the whole philosophy... but you can easily tell which power delivery you like better... I guess it could be difficult to test drive a 73RS... but u can easily compare 996TT to GT3.
Do it, and focus on just the power delivery, throttle response etc.
The 996TT will exhilarate you on coming out of a turn, when in 2nd gear at 2,300rpm you press the right foot.... BAM!
The GT3 will give you pleasure at the other end of the spectrum.
This is why Steve W mentioned the close gear ratios... U want to come out of the same turn at 3,400...
Keep us posted though! Good luck!
Cookie Porsche 05-19-2006 06:34 AM
Depends - some like reds, others blondes...
I disagree with everyone - no 911 engine is cheap!
However, we build a 3.8 7500rpm engine with ITBs and all the goodies and it runs and sounds like nothing on earth. It will pull from 2500rpm like a train and the sound is goose bum stuff. The response is awesome, intake sound is awesome...
You get the picture.
Now I'm building a 3.0 non-silenced twin turbo race engine. It is also not cheap! We're using smallish turbos and a battleship sized intercooler - so I hope for a realistic 450bhp. I think a turbo can sound awesome, the whistling, the blowing, the fire spitting exhaust, etc...
You get the picture again.
I'll never part with my N/A and I look forward to my new blown experience. Kind of having your cake and eating it.
Evolution is part of the fun. Start N/A and evolve.
petevb 05-19-2006 09:37 AM
A couple thoughts.
1. I'm wondering what car this is going into, and what trans you hope to use. Turbo motor = no 915, which can lead to a slippery slope, or a different, heavier car.
2. A "wild" cam on the 3.6 motor will be limited by the valve relief. So if you use the stock pistons you're either stuck with 993 cup/ GT2 cams, or you do different pistons (not sure about the practicality of piston mods). If you don't do the pistons it makes the engine management and ITBs a bit of a waste. If you do pistons, might make a 3.8/3.9 more attractive.
3. Data point for the N/A motor- my just dynoed motor is similar to what you're talking. 7500 rpm redline, cup cams, Vram, RS valves, lightweight retainers, custom burned chips for both 91 and 100 octane. Makes a bit over 320 hp on pump gas, and about 330 hp on 100 octane.
I went the high revving NA route for the reasons you listed. After owning a bunch of fast NA and turbo cars I find I like the NA significantly better if it's "fast enough". In this case I decided 330 hp and 2000 lbs is fast enough, at least for now.
strokher racing 05-19-2006 06:01 PM
I would go with the 3.6 turbo route hands down. You can easily make 600+hp with a basic long block
Wayne 962 05-19-2006 06:52 PM
Longblock, no. But everything else required makes it an expensive proposition...
-Wayne
Jeff Alton 05-19-2006 08:07 PM
You are telling me!! I just added up my cost to date on my 7500rpm 3.4 with ITB's and programmable ECU....... OMG!!!! Wish I did not own a calculator!!!!!!!!
But then again, I prefer the feel of sharp throttle response over the big turbo rush, makes the car more drivable on the track with my moderate skills.
Cheers
dean 05-20-2006 04:26 AM
Here is my data point
My fairly stock 3.0L 930 with EFI puts out 350 RWHP on a DynoDynamic dyno. That was at 13 lbs of boost. Those ain't no DynoJet #'s. I have now turned the boost up to 18 or so.
So I think if you want to make power go turbo and if you want to make noise go N/ASmileWavy Sorry I couldn't resist:p
RarlyL8 05-20-2006 10:09 AM
Dean there's a lotta truth to that statement. Ricers are a good case in point.
However, some sounds are just as intoxicating as power.
beepbeep 05-20-2006 09:33 PM
It's a highly non linear curve between cost and performance. It's hard to judge where break-even point is but for most people, curves for cost per hp for N/A and Turbo will cross at roughly 300hp and after that N/A curve will raise sharply, going into infinite beyond 400hp ;)
So it's all about picking the power level, budget and engine character.
Craig 930 RS 05-25-2006 12:29 PM
Hey PeteVB!
What's the update on my former 3.6 Varioram car - the one I used to own - and you now have?
Pics?
dwightp 05-25-2006 06:07 PM
N/A
911teo 05-26-2006 06:07 AM
I think you nailed it with this post.
Granted the break even moves up and down depending on the engine... but for a 3.6 aircooled motor I think you are exaclty right.
On a different note I have noticed how all the major manufacturers are moving away from forced induction towards n/a enines.
Ferrari last turbo car was the F40. Since then only N/A for their exotics.
Lamborghini... V10, big capacity N/A
BMW... high revving N/A
Audi for their RS4 went from a twin turbo to a high revving V8
Mercedes-AMG is ditching their superchargers for high revving V8s
Pagani Zonda has an AMG n/a V12 in the back
McLaren F1.... BMW n/a V12
Porsche... CGT is a high revving n/a V10
I guess when you can go up in displacement (like all the above cars) then acheiving 500-600hp is not cost-prohibitive with a n/a engine.
So Goran really got it right. Try to decide how much HP is enough.
If in the 300-350 is ok then the advantages of a N/A engine are clear.
If you want above 400hp then turbos is the only way to go.
dean 05-26-2006 02:45 PM
All the above cars are boorrringhttp://www.pelicanparts.com/support/smileys/king2.gif
Flame away my friend
Facey 05-26-2006 03:46 PM
gotta remember delivery.
power delivery is huge as to how fun a car is to drive, and alot of the time how fast it really is.
have a 200hp inscrease as boost kicks in isn;t going to be hugely useful, as it'll just spin 9/10 times.
a nicely cammed up, free flowing, high compression naturally asiperated engine i believe offers the truest bliss experience.
i've driven in dp 935's and crazy hopped up rx7's, skylines and 300zxTT.....the best experience i've had yet was in a 1700lb 76 911 with a 210hp 2.7L in it....
the one truly nice advantage for a turbo car, is that it can have a smooth idle, et good fuel mileage out of boost, and when u need it to, offer a seriosu punch.
however reliablity isn;t there, turbochargers add serious stress on an engine, and i know rev's do also, but an engine running 1 bar spinning 6000revs is the same as an n/a running atmospheric @ 9000rpm.... the power output should be similiar also, if both have been flowed properly. (9000rpm is unrealistic in most cases).
my point is that a 930 will not out run a 964rs, it has too much ground to make up. sure on a mile long straight away, but not at any reasnoable speeds.....
i investigated the turbo 3L route, but its just not the same.... i ended up choosing a high reving 3.5L (can u say "oversquare"). and in a 2300lb car it should move with most turbo's w/o problem.
remember unless your on a race track, its not how fast u go, its how much fun your having. and not being able to talk to the person next to u because above 5000rpm it just screams....is fun.
beepbeep 05-26-2006 05:23 PM
My opinion is somewhat skewed, being a "turbo guy" (I do own a BMW 318is though!) but I do believe that correctly done aircooled 911 turbo engine will live longer than it's contemporary N/A engine beyond >300hp output.
