-   -   harsh noise on deacceleration (http://forums.pelicanparts.com/911-engine-rebuilding-forum/283126-harsh-noise-deacceleration.html)
hcoles 05-16-2006 06:03 AM
About 6k miles ago I rebuilt the top end of my 3.2 G50 89.
So far 7 track DE events and street driving to work.
There is a "harsh" noise and now seems like vibration when the engine/trans is hot and deaccelerating or compression coasting downhill. The only thing I can think of is something is getting more and more worn in the tranny or the exhaust system has some part changing or getting loose. I have the cat out. This has definately gotten more noticable overtime starting after the rebuild. At first I thought is could be that after the rebuild the higher compression was making this sound, now I don't think so.
Any ideas? As far as I know the tranny hasn't been opened up. Now at 78k miles.
Thanks,
-Henry
BReyes 05-17-2006 11:00 AM
Have you inspected the half shafts?
Good luck!
hcoles 05-18-2006 06:42 AM
good thought, I'll check, thanks
hcoles 05-22-2006 08:58 PM
ok, I checked the half shafts and all the cv joints felt solid with no play.
I borrowed a muffler today and swapped it in...no help.
This is starting to get worrysome. Vibration very pronounced at 2650 rpm, smoothes out above and below. Not very noticable when things are cold. When put the clutch in and keep the engine rev'ed to 2650 things get better but don't go away...almost like the vibration is coming from the engine and gets transmitted to the car through the transmission. We are sort of thinking loose flywheel at this point. I'm starting not to like this at all. I used new flywheel bolts and red loctite but who knows I may have forgot to torque...I really doubt it. It seems like it is something that is suseptable to a pronounced harmonic vibration.. layshaft? cam chains? We will need to put 2 Carreras side by side and listen with the stethescope again.. maybe we can find something different sounding...may have to get under the car and listen around the bell housing area. Any ideas appriciated.
lindemans 05-23-2006 04:31 PM
Could it be one of the 4 engine mounts ?
These are made of metal and rubber and could cause (as we call in Dutch) "distribution of sound/noise" from the engine / gearbox to the metal chassis.
Forces on deceleration may cause metal to metal contact and associated transmission of vibrations to the chassis.
hcoles 05-23-2006 04:57 PM
good idea...this was mentioned today over at Jerry Woods place.
They are thinking clutch is falling apart or wheel coming loose, but I like your idea...may be why worse when going downhill and seems to be not as bad when things are cold (rubber stiffer) or maybe the engine is moving and hitting e.g. the sway bar. Maybe I can rig something to pull the engine/mounting system to one side and then see if I hear a difference... thanks very much
make that flywheel coming loose and not wheel
hcoles 05-24-2006 08:27 PM
got under car last night and ran it on the lift....very harsh noise coming from the right side header where the three pipes collect...
today pulled plugs and did compression check...fairly consistant compression numbers about 130 plus or minus with engine warm, plugs look very much the same. I got some pictures and can post tomorrow when I get them out of the camera.
At this point I don't think any mounts are grounding out or something hitting the chassis because I can get the noise without the car moving and not changing the revs much...just sweeping up and down across 2650rpm is where I get the harshest noise. But I do need to do more to completely rule out mounts and phyiscal grounding.
Stay tuned...
MBEngineering 05-25-2006 10:23 AM
HI has your car got the exhaust support onto the gearbox part No 950 301 401 00, if not try that it was added to stop noises like the one you have. it is approx £18 / $33.93
regards mike
hcoles 05-25-2006 10:50 AM
Mike,
never heard of this...do you have a picture?
last night checked plugs and did warm compression check.
compression results..
I was not able to view gauge when cranking and did get a few odd readings
1 - 135, 126 - average = 130.5
2 - 126, 129 - average = 127.5
3 - 140, 129, 125, 133 - average = 131.7
4 - 127, 129 - average = 128
5 - 129, 127 - average = 128
6 - 141, 131 - average = 136
I have a composite picture of the spark plugs and will see if can add the image in this email...
hcoles 05-25-2006 10:55 AM
here is a picture of the plugs from last night after driving home from work 7 miles and running the engine real easy...what are the white dots?
http://forums.pelicanparts.com/uploa...1148579682.jpg
MBEngineering 05-25-2006 01:57 PM
HI do you have the PET system, if you do look under 911 1970>1989, and then1989,group 2, illustration No 202-05 No 24, it fits from the exhaust flange bolt to the gearbox casing, the plugs look a little weak and the dots could just be the bad grade of fuel, if the light is the same on the No1 plug which looks ok then i would say you have some faulty injectors/spray pattern, injector cleaner in the tank and richer mix'
regards mike
jadeblaquiere 05-25-2006 02:49 PM
Is there perhaps a crack in the exhaust header or flange?
My experience is that cracks in the exhaust can make some really horrific sounds (imagine whacking something with a ball pein hammer)... these tend to be more pronounced when warm and a little backfiring caused by richness on overrun would certainly emphasize it...
It's a bit of a stab in the dark, but it should be much easier to look for than a lot of problems...
MBEngineering 05-25-2006 03:15 PM
HI it's a 3.2 1989 carrera and i asume is still STD injection, with that the injectors will be SHUT OFF on the over run so no fuel !!
regards mike
hcoles 05-25-2006 03:59 PM
Mike, I have PET. I'll look and it could be a good addition...but seemed to run ok for 4 years that I had the car without. I'll check it.
Tonight I'm going to switch the exchangers...one hope is that a tube inside the right exchanger has a crack...I hope it is something like that. The other night as mentioned very harsh noise on right header compared to left header...I hope it is the header/exchanger.
Re. injectors... yes...I've been worried about these for sometime now. I need to send and get matched/cleaned. Not sure of a place there is Maron and EBS and I think now a bunch of places because the tuner market guys are sending in injectors to get checked. I have run Techron a number of different times. I should just bite the bullet and send them to EBS and be done with that.
-Henry
hcoles 05-25-2006 04:07 PM
Mike, I now notice your comment re. no fuel and getting the harsh noise..means during deaccel all the fuel related/combustion related contributors should be gone or reduced....does this point to crack or ? inside one of the header/exchangers? I'm just sort of thinking out loud here, is that your point? Good thinking...
and jadeblaq...good comment as well re. cracked exhaust parts...and I have had some back firing when shifting at full throttle at the track... e.g. on the front straight at Laguna Seca from 3rd to 4th..I wonder if this has caused a break in the "header" or vis. versa... I've been short shifting a bit and that issue is reduced now...
I really appriciate the comments and all the good thoughts..
MBEngineering 05-26-2006 01:57 AM
HI check the micro switch on the throttle housing, as this tel's the ECU the throttle is closed and to shut the fuel off, it could not be working correctly and over fueling???
regards mike
Jandrews 05-26-2006 06:35 AM
Does it run strong under acceleration/load?
JA
hcoles 05-26-2006 07:37 AM
John,
It seems to me to run strong under WOT...but...when Rich and head engine mechanic at Jerry Woods took it out they said it seemed to be down on torque....who knows they may be used to driving cars that actually have power to weight ratios that are mentionable
hard for me to tell, I'll run it against some other cars around here that are the same and see if the accelerations are the same.
Some guys are coming over and we are going to work/think about this some more.
Last night I switched right for left the exchangers and filled them with water to see if a leak....no leaks and no increase/decrease in vibration
I'll see re. the switch closing when the throttle is up...
Thanks for thinking on this...sooner or later I'm going to find it I hope...I don't really want to track the car too much more until I find the root cause
-h
hcoles 05-26-2006 07:46 AM
My latest thought...one of the cam chain tensioners has collapsed and is now resting on the "Jerry Woods spacer" I placed inside the tensioner. This means the chain could be operating OK but would be loose causing a vibration being worse at a given rpm...
hcoles 05-26-2006 07:58 AM
Mike,
I found the 950 301 401 00 in PET. I'll ask my mechanic if anyone has put one on my model or if he has seen one installed. Thanks,
-Henry
Jandrews 05-26-2006 09:02 AM
I'll tell you what... my RS motor had an "elusive vibration" for months and months. I drove it on the track, and was still outrunning SC's and Carrera's. It was running at approximately 80% power, but still ran pretty darn good. It turned out that I had a spark plug that was firing, but producing just a weak spark. This was very hard to diagnose, until I finally swapped in some new plugs. What took me so long to swap plugs, is that I was getting fire in every cylinder, so I thought ignition was good. I tested EVERYTHING.
I will say this, it is amazing how well these cars run on 5 cylinders (not good by any means, just not horrible like you would expect). And also, they don't seem to "miss" hard the way other engines do. They just generally degrade on power, which is what makes things very difficult to diagnose.
JA
MBEngineering 05-26-2006 11:37 AM
HI if the chain tensioner has collapsed, you will have a bad rattle at app 2500-3500 rpm and then above it will go quiet again,
regards mike
Rob 930 05-26-2006 12:45 PM
Any possibility of a rod knock from a bearing? Have you examined the oil? Is oil pressure okay on decel? Has it changed over time (and gotten lower, for instance) since you first ran the engine?
hcoles 05-26-2006 02:21 PM
Nobody so far has mentioned rod knock.
In the last couple of months a very slight "ticking" noise has developed...sort of like the ticking I had before when discovered some valve guides were worn large. Could be a valve with slight need of adjustment. This slight ticking doesn't seem to be related or the same sound at all. Oil pressure seems same as after the rebuild 1bar at hot idle and 4bar or a bit more when running.
Probably will do some more listening with the stethoscope and compare car A and car B with same type of engine and recent top end rebuild also.
hcoles 05-26-2006 04:06 PM
Here are a couple of pictures showing what my exhaust valves and headers/exchangers look like..these are the worst positions.
I think I have about 8k miles on the top end rebuild at this point.
I don't know if this helps identify the vibration issue....the colors on the valves look very "white" but that may mean it is running on the lean side when putting around town which is probably ok. The build up in the header is a bit disconcerting.
On most of the exhaust valves there is just a small trail of black downstream..I guess this is where a small amout of oil is burning off...
http://forums.pelicanparts.com/uploa...1148684430.jpg
http://forums.pelicanparts.com/uploa...1148684445.jpg
WERK I 05-26-2006 04:38 PM
Are you running an aftermarket chip on your ECU?
hcoles 05-27-2006 06:52 AM
Currently running what I think is the stock chip that came in a box with the car. I put this stock chip in the car just after I got it about 4 years ago. Do you think the car is running lean?
The one interesting comment...above was that I can get the noise/vibration when coasting against the engine compression...at this point the injectors are supposed to be off or at least not putting out much.
WERK I 05-27-2006 07:29 AM
Don't know if you're running lean, but it appears your exhaust gas temperatures appear to have been hot, very hot. Is your exhasut valve really that white? Wouldn't worry about the exhaust header buildup. It really doesn't look that bad. You could have had that before your top end rebuild from worn valve guides.
The noise still could be anywhere. The chain tensioner collapse, rod knock, transmission bearing, pinion bearing, etc. Btw, do you have a Limited Slip Differential in your car?
An experienced Porche wrench could easily spot the area just by the sound and feel alone. These cars have a personality all their own. :)
BReyes 05-27-2006 08:38 AM
Sound bite?
So what is the coroboration at this point.
Don't drive the car, or it is fine? Earlier you mentioned, ft shifting and that is no problem. Why were you short shifting?
hcoles 05-27-2006 09:42 AM
short shifting to avoid back firing at shift from 3rd to 4th e.g. on straights at Laguna and Thunderhill - shift at 6 instead of 6.3k
Porsche wrenches - Don Wise and head mechanic at Jerry Woods have listened and confirm the noise vibration but no clear root cause ideas...
the exhaust valves are pretty much the white that you see...would like to hear if this is really an issue...are my exhaust valves much whiter than what is standard...car seems to run ok
I guess I'll try recaping:
- noticable noise/vibration most distictive at 2600-2700rpm
- most noticable when coasting down against the compression of the engine in 2nd, 3rd, 4th, stops when clutch pushed in and engine allowed to go to idle, somewhat noticable when clutch pushed in but engine reved up to the 2600-2700rpm..vibration is connected to engine speed and not transmission gearing change
-can sort of be duplicated when slowly free reving through the 2600-2700 range, also duplicated just static reving in the 26-2700 range
- noise/vibration can be duplicated with car stopped and in neutral but is too a much lesser extent
- using stethescope under the car.. could seem to notice the vibration on the right heat exchanger where the 3 come together before going into the cross pipe
things thought of and done:
- muffler - borrowed a muffler and swapped - no change
- heat exchangers - swapped right for left - no change
- one cylinder not working - compression check and look at exhaust valves - no obivious cylinder not doing work - person mentions exhaust valves look to be running hot -
- found loose bracket holding cross oil line - tightened back up - no change
- half shafts/cv joints - felt and the feel fine with almost no play and feel stiffish
other ideas: flywheel getting loose, piece of clutch came off or steel spring broken or came off (I am running a steel spring clutch compared to stock rubber), partly colapsed cam chain tensioner (I have Jerry Woods tensioner stops installed, rod knock, sump not getting schavanged and crank hitting oil, cam chain ramp broke
sort of sounds like maybe issue is connected to something happening around the input shaft to the transmission, since the noise is really transmitted when the engine is pushing against the transmission...leads me to think the noise is being generated on the input shaft or transmitted primarily through the input shaft
Again, I appriciate the comments and ideas...
MBEngineering 05-27-2006 12:51 PM
HI try the dual-mass flywheel as thay do not like doing what you are doing to it, raging it round a track, i had one, on a 3.3 turbo give up on a track day, at a the track, striped it and had to cut the flywheel to get to the bolts, as it had moved so far round the bolt holes did not line up.
just a thought???
regards mike
BReyes 05-29-2006 07:44 AM
Would Don or Jerry go into the boxes or into the 915. Is dropping it the first step to diagnosisi? Then 4-7k, right? If you drive her on the street you avoid this.
How about this, when did it really start? What is it going to cost me if I don't get back to when I was certain vibration was absent?
You have done so much work to date on this. Thank you for sharing with us. As I write this, I try to put myself in your shoes. I realize the amount of work required, to go in, drop it, go into those components, refurbish necessary ones, clean her up well, re-install drivetrain. The first thing PCars really require is time. The term service comes to mind. If you are going to do all this your self, have you thought about about having a spare (motor/trans) for use.
Regards,
hcoles 05-31-2006 08:39 PM
hope this isn't getting too boring for y'all
I'm getting a bit tired of trying things and thinking about it..
update:
Mike...I found the "bracket" part that goes from the exhaust flange and to the trans case - installed it
also at the same time took both belts off, alt. and ac compressor. I always wondered what that was..came in a box with the car.
went for a very short run...not much change still have the vibration.
after putting the belts back on I left the "bracket" on and went for a longer ride...it was definitely not worse maybe a bit better..I think I still have an issue.
I'm getting ready to pull the motor and trans and check out the flywheel and clutch area and get that assembly balance checked...need to find one around here (San Jose CA)
That's about it for now...thanks for the thoughts
-h
hcoles 06-03-2006 03:31 PM
if anyone is still looking at this..I put in a new post....dropped the engine this morning and looked at the clutch, flywheel and pressure plate. Can't see any issues except the clutch disk heavy springs are loose....is that OK? Seems like there should be no play...the thin springs ( 2 of 6) are in compression. Thanks,
-Henry
hcoles 06-12-2006 07:51 AM
got the engine back in on Sat.
one of the rear engine mounts seems to be cocked.
I'm thinking that I need to check that the rear of the engine is centered in the car and I hope the rear mounts can be loosened and will float to center and then I'll torque everything back down...
is this how it works?
how do I find the center at the rear of the car? is the center of the hold for the trunk latch the center?
hcoles 06-12-2006 12:34 PM
FYI - I asked my mechanic this morning....the engine is not supposed to sit in the center of the car...at least the rear of the engine isn't.. not sure about the tranny end... the offset seems to be about 3/8". We looked at some other Carreras and same thing...engine is offset from center...
hcoles 06-13-2006 10:40 PM
ok, engine back in the car and running.
I would say the issue is fixed....no noticeable vibration at 2650rpm.
The vibration moved a bit to 3000rpm but is different and much less
I would now say the root cause is motor mounts. When I put the engine back in the car I probably shifted the mounts around a bit and the vibration is changed.
The other things I did that might have an effect:
- injectors sent to WitchHunter and cleaned and balanced
- flywheel and pressure plate balanced, clutch disk was balance checked and was fine
- found that the WOT switch was not working, cut it apart and cleaned and JB Weld back together
- cleaned the tracks inside the air flow meter
- changed the air filter to now have the pleats horizontal, I didn't realize that is needed but makes sense..I should know better
- did valve adjustment...they were a bit on the loose side
I guess that's about it for this thread...I'll probably try moving the mounts around a bit and see if that changes things..I now notice that the left rear mount is a bit cocked so I'll see if I can get that to a more relaxed position.
lindemans 06-14-2006 09:13 AM
Wow, good to hear you found it; I'm positively surprised my guess was right.....and it's in the end a cheap fix.
What you may do is lubricate the rubber pieces with WD40 or similar to make them slide into place; or slightly jack-up the engine a bit to take the load off the mounts to have them seat....
