-   -   Mufflers Sound (http://forums.pelicanparts.com/911-engine-rebuilding-forum/283610-mufflers-sound.html)
GotaT 05-18-2006 01:22 PM
Mufflers Sound
Any of you use a Magnaflow muffler on your 911, or Other? I have a 2.4l w/ Webers and considering installing a new muffler system w/ 2 outlets. Of course on my 71 car I will have to cut out a passenger side hole, but not a problem. Im hoping for something deep and rich sounding, not raspy or poppy.
Ever heard of this one or used it?
http://www.rev2red.com/advanced_search_result.php?keywords=11378
http://cgi.ebay.com/ebaymotors/Dual-2-25-4x9-Oval-11-Body-MagnaFlow-Muffler-SS-11378_W0QQcmdZViewItemQQcategoryZ33636QQitemZ80354 67278QQrdZ1QQsspagenameZWD1V
Thanks!
JeremyD 05-19-2006 06:51 AM
I have the magnaflow
#14386 with the 4" tips #35136
shoot me an email at jdixon1636 at earthlink dot net and i'll send you a sound file (.wmv) http://forums.pelicanparts.com/uploa...1148046710.jpg
mb911 05-19-2006 09:04 AM
definatly low rumble with the magnaflow
Boxer 6 05-20-2006 05:02 AM
Here is mine.
http://forums.pelicanparts.com/uploa...1148126523.jpg
GotaT 05-20-2006 07:04 AM
Nice.. How do those sound?
1fastredsc 05-20-2006 05:28 PM
I have a magnaflow 2 in 2 out. Definitely a low rumble at idle, and with my sc it stays reasonable until 3500 rpm, then it goes stellar nasty loud.
GotaT 05-21-2006 10:26 AM
I wonder how it would do w/ my 2.4. I wouldnt like it to be too loud on the highway around 3700 to 4200... Or does it mellow out once at a constant speed?
JeremyD 05-21-2006 12:46 PM
Actually mine only has a little buzz between 2600 -3000 rpms. Change a gear up or down and it goes away.
rev2red 05-22-2006 10:01 PM
Re: Mufflers Sound
Thanks!
This is Steve from Rev2Red.com. We have two of the mufflers 11378 in stock and ready to ship. Place your order before 3pm and we will have your order shipped same day.
berettafan 05-23-2006 05:04 AM
Re: Re: Mufflers Sound
i am reminded of a certain skit involving a food product that was popular decades ago. SmileWavy
GotaT 05-23-2006 05:39 AM
Steve. I noticed the picture on the website showing Inlets on all four sides. Where are the Outlets.. or does this mean that Any of them can be used as either in or out.
Whats the difference (sound wise) between the 11378 and 14386 like JeremyD has on his car other than the size inlets(2.25 to 2.5)
My car only has the 2.4, which would be the better sound?
rev2red 05-23-2006 09:07 AM
The muffler can be flipped either way. Each side and be either an outlet side or inlet side. There probably won't be much of a sound difference. Part number 14386 is a few inches longer so it might be a little quieter. I'm sure they will both sound great on your ride.
GotaT 05-23-2006 10:27 AM
Can it be set where One side has both the inlet and outlet, and the other side the same?
kenikh 05-23-2006 12:23 PM
Steve at Rennsport also recommends and sells these. Supposedly they work great with headers or exchangers.
rev2red 05-23-2006 12:28 PM
I dont think you can do that. Magnaflow makes Camaro/Firebird mufflers that use a similar design. The part numbers are 12266, 12265, 12267, 14266, 14267, 14277. Those are designed to have both and inlet and outlet on the same side of the muffler.
GotaT 05-26-2006 02:08 PM
Jeremy D.. How are your Inlet and Outlets set on your muffler... Is there One Inlet and Outlet per side.. It looks like I can see both Outlets on the bottom.. and assume the 2 inlets are on the top.
Rev2Red .. whats the difference b/n 11378 and 14386 as far as inlets/outlets and sound... my car is only a 2.4.. not the beefy 3.2 or anything.
JeremyD 05-26-2006 03:07 PM
yep two in at the top - two out at the bottom.
