-   -   906 Cams (http://forums.pelicanparts.com/911-engine-rebuilding-forum/283965-906-cams.html)
rfn026 05-21-2006 05:18 AM
906 Cams
I have a set of 906 cams I'm thinking about putting in my 1973 911. I have the S pistons and Webers. Does anyone have any experience driving an early 911 with these cams?
I can deal with a little loss of mid range torque but I don't want a high rpm screamer. This is a street car.
Richard
JGalt 05-21-2006 06:41 AM
From 6 to 9 it is "dearly beloved we are gathered here, ..."
Below 6, it's wake me when it's over.
jluetjen 05-21-2006 09:14 AM
If you don't want a high RPM screamer, don't get 906 cams. They've got little if anything below 4000 RPM (which is why Porsche didn't even start their dyno runs on carb'd 906 engines until 4500 RPM)*, and really don't come "on-cam" until 5500 RPM and pull strongly until amost 8000 RPM. Now if you haven't ported your engine's heads, and they're not S heads, you'll wind up with an engine that pulls strongly from 5000 - 6500 RPM and then runs out of breath.
Pick a 2000 RPM rev range where you want your engine to be strongest, and then you can start to talk about what cam will be right for you.
* Note: Engines with 906 cams can be driven at less then 4500 RPM, but only at part throttle. Even then they'll still be tempermental. MFI helps this quite a bit compared to carbs.
gumba 05-21-2006 04:06 PM
My 2.8 twin plug had 906 cams w/46mm Webers. They weren't happy until I hit 4500 + rpm. Great for the track, less than ideal for the street.
kenikh 05-22-2006 10:45 AM
Here's a thread I started over on the S board asking a very similar question:
http://www.early911sregistry.org/forum/showthread.php?t=10662
jluetjen 05-22-2006 04:58 PM
Here's a chart that I did a while back based on the factory dyno charts for the different 2 liter engine configurations. The bold red print shows where that particular configuration is best. I've also plotted the results out graphically.
http://forums.pelicanparts.com/uploa...1148342292.jpg
