question re: 3.0L 'piston kit'
Does anyone know of a kit (don't know if it was OEM or not) to upgrade the 3.0L to higher compression and slightly larger displacement ? I was talking to a fellow today who knew a guy who did that upgrade (when it was time for rebuild) and it significantly woke up the engine.
Thanks. |
Short stroke 3.2 kit.
Mahle makes one and so do we. 70.4 mm crank and 98 mm bore. any comp. ratio you want. PM me for price. |
The 98mm pistons (as recommended by Henry) are the only displacement upgrade you can do without machining the case.
You can also use LNEngineering cylinders and J&E pistons. I'm using that setup now (albeit with 100mm versions for 3.3L) |
| All times are GMT -8. The time now is 04:35 PM. |
