Garage dweller
Help! - Weber intake manifold gaskets
I've searched these forums but I am way confused.
I have my Webers off for general cleaning and intended to replace the intake manifold gaskets - the 12 in total gaskets that go above and below the plastic spacers that sit between the heads and the manifolds - but I can't determine the proper new gaskets to purchase. I have a 2.7 with 40 IDAs - the current gaskets have a perfectly round opening, but the pictures displayed by our host appear to have a non-circular opening - see below ![]() What is correct? Thanks, Don
Don Sjolin IIIEURO AUTOWERKS 616.874.7932 |
gaskets
what you need are the conversion gaskets from PMO that deal with the CIS port to the weber manifolds/insulators
www.pmocarb.com or fax 310 394 6313 Richard Parr Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
Since you have the carbs off you should be able to see what you need. If your 2.7 has CIS heads then they should have the funny shaped port you see in the picture.
-Andy
72 Carrera RS replica, Spec 911 racer |
19 years and 17k posts...
Don,
How do you like your Webers? I had my 2.7L CIS engine converted to Webers and just drove the car home the week before Christmas and I cannot believe the difference! What has been your experience? What's your estimated MPG? Thanks!
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
