-   -   What do you guys think of these p/c's? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/284380-what-do-you-guys-think-these-p-cs.html)
id911T 05-23-2006 12:55 PM
I noticed this on ebay today. They aren't factory MAHLE, and it appears from the description that he's having them made somewhere. I don't need p/c's now, but I may later on, and the price is right. What do you guys think?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=8068511723&ru=http%3A% 2F%2Fmotors.search.ebay.com%3A80%2F%3Ffrom%3DR40%2 6satitle%3D8068511723%2B%2B%26fvi%3D1
Usable? Chinese junk?
kenikh 05-23-2006 01:13 PM
Those pistons look cast. I don't like cast pistons.
id911T 05-23-2006 01:17 PM
I was under the impression that most 911 pistons were cast, with the exception of S, RS, and other racing pistons. So says the gospel according to Wayne.
kenikh 05-23-2006 01:28 PM
Yes, they are mostly cast. That said, the hi performance engines were forged for a reason. I guess it depends on your intentions. Stock E (or less) rebuild, then they are OK. Me, I won't use them.
cnavarro 05-23-2006 03:11 PM
You get what you pay for :-)
id911T 05-23-2006 06:58 PM
True, you do get what you pay for, but consider this. MAHLE sells p/c's for vw engines, much like the cast iron cyinder/cast piston combination used on the 911t's. In fact, from the ones I've seen, the quality is identical. Since there are only 4 cylinders for the vdub, we can say that the set of cylinders for the 911t should be 3/2 more than the vw set., assuming quality sets the price. The vw sets go for around $200, so the 911t p/c's should be $300, right? All I'm getting at here is that if you got what you pay for, production p/c's could be had for $500 new. Seems skewed to me.
vinny c 05-23-2006 08:22 PM
believe fastclassics is offshoot of born2bfast. "motormeister north"
Craig 930 RS 05-28-2006 09:45 PM
I like his feedback responses on EBay - in the past 17 days:
Comedy of errors.
In my opinion this person is thief,name should be"Fast Talker,not Fast Classics"
The rest ain't so hot either.
Caveat emptor stuff -
