piston rings or new pistons
There ar a number of suppliers for new piston rings for 2.0L 911E engines. There ar very few suppliers for new pistons/cylinders, and they are very expensive!
When are new pistonrings an option?
Old 06-25-2006, 12:14 AM
Still Doin Time
asphaltgambler's Avatar
New rings are required when A)Worn to the point past acceptable leakdown attributed to the rings and or the pistons themselves. B) Excessive heat through friction where the spring tension has been lost.
Old 06-25-2006, 06:09 AM
89turbocabmike's Avatar
Just replacing piston rings is an option if your cylinders and pistons still measure within specification. This link should give you some more info: Checking cylinders
Old 06-25-2006, 07:32 AM
Hello, prutzer.
The usual reason to scrap these pistons is the top ring groove wear.
It is usual for these grooves to be out of spec in over half the engines I have seen.
It is of course quite common for people to try to ignore this and just rering..it often works, for a short while..ultimately the ring will break.
Remember the costs in labour time and parts to just take the motor apart, clean it properly, and rebuild it..and you will find the cost of new pistons becomes economic IMHO.
Plus, you have the opportunity to raise the CR, use a lighter more modern design (NB JE pistons are actually heavier and IMHO inferior to the original Mahle 69 S piston), and hva valve pockets which will accommodate a more modern cam profile..
Kind regards
Old 06-25-2006, 09:23 AM
shbop's Avatar
I'm with DavidPPP, on the top ring groove spec. I just went through this with my 2.0. I also opted for the JE piston option.
Jon
Old 06-26-2006, 06:57 AM
Measure everything, ie gap, ring side clearance, piston skirt to cylinder. If everything is within spec then go with the option of installing new rings. I like the Total Seal ring packs.
good luck,
Rusty
71 911E
55 PreA speedster
85 Turbo look Cab
62 Twin Grille Roadster (getting close)
Old 06-29-2006, 09:31 AM
