-   -   One Case Journal Pitted (http://forums.pelicanparts.com/911-engine-rebuilding-forum/285605-one-case-journal-pitted.html)
alphie 05-30-2006 07:36 AM
Can someone please comment on this journal? All the other journals are in decent shape but this one has lots of pitting. I will get the case measured, but what if any effect does will this have?
http://forums.pelicanparts.com/uploa...1148999561.jpg
cstreit 05-30-2006 07:40 AM
That's odd, don't think I've seen that before but I suppose an extended sitting interval without an oil-change could do that. Acid's build up in oil over time and a long interval (say an entire winter with old oil?) might do this?
I doubt it will affect your engine as the bearings still have they're primary support in place, but I suppose it couldn't hurt to have it checked.
alphie 05-31-2006 08:24 AM
One pit is actually deep, should I address this in any way? can it be filled?
cstreit 05-31-2006 01:01 PM
I'm sure a decent welder could fill it, but then it would have to be bored. However once again I don't think it would be necessary. Unless that pit is 1/4" wide I don't think the bearing would "sink" into it.
Jeff Alton 05-31-2006 02:22 PM
I think you will be fine.
Cheers
davidppp 05-31-2006 02:50 PM
I think it depends on the cause.
If its is a worn case..problem...
If its only pitting due to local erosion, or casting defect, and all is stright and in spec..absolutely no problem..
If you want belt and braces I have glued shells in with success...
Kind regards
david
cstreit 05-31-2006 09:50 PM
Belt and Braces? You're showing your age sir!
alphie 06-01-2006 05:24 AM
I confess to not exactly knowing what David was saying. I assume it means something like 'to really beef it up...'?
David, can you elaborate on gluing the shell in? thanks!
cstreit 06-01-2006 12:48 PM
Wearing a belt AND suspenders...
davidppp 06-01-2006 01:06 PM
Sorry, guys!
Yes, I have twice used this bodge...
You need to use some high tec glue..I used something recommened by 3M tech dept..it is a cheeep alternative to a linebore in the 356 motor..
I would say that on the 911, just one slightly oversize housing would not make me linebore..hence the gap-filling glue solution.
But if its not stright..linebore..
Kind regards
