Will 2.2 911T pistons work in a '71 911E?
Will there be any valve to piston clearance issues with E cams?
Kelvin '67 912
New Zealand
Old 05-30-2006, 05:01 AM
PRO Motorsports
Tyson Schmidt's Avatar
Won't work.
You can have the pockets opened up. You can go just deep enough to clear E cams, or maybe a little more if you machine the pockets by, IIRC, 2.5mm deeper.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 05-30-2006, 04:02 PM
3 restos WIP = psycho
kenikh's Avatar
The compression ratio trade off and the cost of machine work just isn't worth it. If you've driven the 'E' in question, you'd undoubtedly be disappointed by the results.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 05-30-2006, 04:54 PM
I agree..do not do it!
You need all the compression you can get..I have tried this combination..
Kind regards
Old 05-31-2006, 01:20 AM
Stranger on the Internet
patkeefe's Avatar
Is this applicable to the 2.4T also? ie, if running "E" cams with 2.4 T pistons, is there just not enough compression ratio to take advantage of the E cam profile? Probably best to find 2.4 E style pistons?
Thanks!
Pat
Patrick E. Keefe
78 SC
Old 06-03-2006, 10:08 AM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
Pat, yes, it is. As you go "hotter" on the cams, I'm sure you're aware that the amount of time that the valves spend open increases. This reduces the effective static pressure at low RPM, and gives you no torque. The 2.4T had about 7.2:1 compression, which is VERY low. Increasing the duration and valve lift will only exacerbate the problem of low compression at low RPM, but at high rpm, it will be more powerful than stock (not a good trade-off, IMHO).
What is a great and reasonable combination is 2.2T pistons/cylinders on a 2.4 crankshaft. You get up to about 9:1 sometimes, this is very good for use with an E cam (like Tyson said). 2.2E and 2.2S pistons produce around 9.4:1 and 10.2:1, respectively, on a 2.4 crank, and about .6 lower if it uses a 2.2 crank.
I don't really think I'd use any 2.4 pistons because the compression is so low (2.4E=~7.8:1 stock on the longer-stroke 2.4 crank!)
Cheers,
Scott
Scott Kinder
kindersport @ gmail.com
Old 06-03-2006, 12:55 PM
