slight valve to piston contact...jumped timing?
for those of you who recall, my 2.7 seemed seized on initial start-up. then it turned out it just wouldn't make 2 full revs, something was blocking inside. pulled the heads last night (those cam nuts are really awful), and was figuring i would see jimmy hoffa in there, or at least a valve head flying around a cylinder. nope.
#4 cylinder has a clear but slight mark on the piston crown from the exhaust valve, an arc about 18mm long, and #6 looks like something small and hard might have been in there for a few revs, a few light gouges at the very bottom of the piston (i could have dropped a washer in there while pulling the CIS stuff off, and then spun it a few times after removing all of the rockers??), but all valves look OK. lots of carbon, but no massive chunks.
here is what i am thinking....this car has pretty crappy oil pressure, and hyd tensioners. could the one bank have jumped time during cranking? has anyone every experienced a jumped-timing incident during start-up?
thnx for your ideas....joe in NJ
Old 06-16-2006, 02:45 PM
That seems like a likely scenario. Another possibility is an over-rev and bent valve not closing. Sounds like time for a rebuild. If the car has crappy oil pressure you'll need to do the bottom end as well.
-Andy
Old 06-16-2006, 03:24 PM
