Less brakes, more gas!
euro911sc's Avatar
What Tap to Clean Head Stud Holes?
I typically get my supplies from MSC. Here is a page of relavent Taps, but they discuss things in terms of 'Thread Limit' which I assume is determining the difference between cleaning and cutting taps.
MSC Supply Pages
Googling 'Thread Limit' produced this page of how to calculate:
Thread Limit Calcs
But, it didn't really answer my question on cleaning out threads...
I already chased 1 hole and then thought better of it... nothing large was cut, just a bare minimum of grime was on the tap. Then I searched here and found I should use a special kind of tap... ok so maybe I only screwed up one hole... I think I can live with that.
So, what do I buy to clean these out?
Best regards,
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 06-05-2006, 11:14 AM
there is a difference between cutting taps and cleaning taps....
I used a cutting tap to clean which was probably not correct...
maybe there is a wire brush type of tool that you can put in the threads and spray brake cleaner in at the same time as turning the brush.
I looked on the web for cleaning taps...I found for english but not metric
Sold: 1989 3.2 coupe, 112k miles
Old 06-05-2006, 11:56 AM
adomakin's Avatar
i would just use an old head stud. I bought a m10x1.5 tap as told in waynes book-turned out to be a cutting tap and not a cleaning tap-not good. after speaking with henry at supertec he advised me that an old head stud will normally do a good job of breaking up any old loctite/crap especially if you use a liberal amount of solvent cleaner etc. just keep working it in and out of the hole and keep blowing out the crap with air/solvent in a can until its nice and clean. thats more than enough. good luck!
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 06-05-2006, 03:16 PM
3.4 Bigger is better
88-diamondblue's Avatar
Grind off a side of the old head stud or a correct size bolt which will help clean the thread and give a place for the crud to accumulate while you are cleaning. Did that with my rebuild and worked well to clean the threads out.
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 06-05-2006, 04:27 PM
This is what I did. I think you'll be surprised how well it works. Dental picks help too.
-Brian
Old 06-06-2006, 10:33 AM
Super Moderator
cstreit's Avatar
I cut a slot in a used head stud with a cutoff wheel... As mentioned if gives a place for the gunk to go...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 06-06-2006, 04:13 PM
euro911sc's Avatar
Cool, I just used a dremel and cut some slots in the old stud and it worked great.
Thanks guys! Beer's on me!
-Michael
Michael
'13 Cayenne GTS
Old 06-06-2006, 06:41 PM
Or a gun brush with some solvent and compressed air.
Old 06-08-2006, 09:40 AM
Both Sears and Snap-On sell the correct metric "cleaning/chasing taps and dies"; one has to buy the whole set (including inch sizes) at Sears ($70?) but Snap-On sells the individual cleaning/chasing taps and dies.
Old 06-08-2006, 09:59 AM
Jim,
The item I could find on Sears that fits the bill is
Sears pn 00942275000 mfr pn 971 2750
seems cheap..$50? or so.
Is this the one?
-h
Old 06-12-2006, 08:10 AM
That's it; I see the price has been reduced but it's out of stock on-line. A Sears store may have it in stock.
Old 06-12-2006, 11:13 AM
