-   -   79 SC disasembly (http://forums.pelicanparts.com/911-engine-rebuilding-forum/287458-79-sc-disasembly.html)
Wil 06-09-2006 12:32 PM
79 SC disasembly
OK, Ive got the head off engine, did not take off lifters, the only thing preventing complete removal is chain restricted by brown plastic chain guide.
It has 2 round fasteners.
How does this chain guide come off?
is there some kind of nut or spring release?
Then, when I get the head off, I can take it down in the shop where there is better lighting to see what I am dealing with.
thanks
GBStu 06-09-2006 01:57 PM
Wil,
I couldn't imagine how I’d have disassembled and rebuilt my engine without Wayne's book, here's the link:
http://www.101projects.com/911-Rebuild/index.htm
Good luck, Stu
Note, each chain ramp "snaps" onto two shafts, the chances of removing them without damaging the ramp is pretty low....these ramps are consumables during a rebuild
boyt911sc 06-11-2006 05:51 PM
Brown Plastic chain guide.....
Wil,
These chain guides your were refering could be easily removed by prying them out. They are just snag tigth held by the 2 metal posts/studs with grooves.
Pry them from behind and will just pop off after sliding a few mm out. Installation is much easier. Just slide them and hear it snap and lock. Hope this will get you moving.
Tony
