Source for Weber throttle shaft coupler?
I'm in need of a throttle shaft coupler for a set of Weber 46 IDA 3C carbs.
Any recommended sources? I was having trouble balancing the carbs ... now I know why. Thanks Eddie |
coupler
I should have one of those, I will look in the am.
Mike Bruns JBRacing.com |
coupler
I have a coupler, it is the newer design, and throttle plate screws if you need them
| All times are GMT -8. The time now is 06:47 PM. |
