jerry woods mods
Hello
i once saw a "jerry wood" mod. on spring loaded tensionner... they told to add a piece under the spring, right ? any advice on this mod ? regards Philippe |
I heard Jerry talk about this last week. They used it as a failsafe. Be carefull not to make it to long, and thus, make your tensioner close to rigid. If I recall, he used this method prior to the clamps now available.
Jon |
abit off center
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
I made some out of 6160 bushing material. If you get, if I remember correctly, a 5/8" motor bushing from OSH the OD is right on.
I can't remember how much I left for play and thermal expansion maybe 1 mm. I cut off a slice with a hacksaw and then sanded to a final thickness...it's a bit time consuming. My feeling is this method is better than the clamp because the parts are contained. I would strongly recommend doing it.
Sold: 1989 3.2 coupe, 112k miles |
