-   -   ARP Head Stud Height Does Not Matter, Look at Pics of my 3.2L Head Stud Comparison (http://forums.pelicanparts.com/911-engine-rebuilding-forum/289028-arp-head-stud-height-does-not-matter-look-pics-my-3-2l-head-stud-comparison.html)
Determined 06-18-2006 10:49 AM
Ok, let's try this again...my pictures did not upload.
Well I'm going to be doing my ARP install this morning and I read everyone's input on the subject, I have to agree with Henry and a few others that it appears that head stud install height does not matter with aftermarket performance studs since they do not use the barrel nuts. To prove it out I installed an ARP and OEM stud next to each other; The ARP was installed all the way in until it bottomed out and then backed out 1/4 turn. The OEM was installed at a deck height of 135 mm (5.315"). I took a few pictures of their resting positions and you can see that the ARP and OEM threads nearly line up. Before I add the loctite any more advice out there? I already thoroughly cleaned out the threads? Oh, one more question....how much loctite should I put on and should it be applied to the case and not the threads on the stud?
Best Regards,
Alexhttp://forums.pelicanparts.com/uploa...1150652832.jpg http://forums.pelicanparts.com/uploa...1150652850.jpg http://forums.pelicanparts.com/uploa...1150652870.jpg
Jeff Alton 06-18-2006 08:41 PM
It takes a extra few seconds each to set the height properly so why not do it? I assembled a cylinder and a head and then put the washer and nut on to make sure I did not go past the threads....
I can't remember the height I used, but I set them all to the tested height.
Cheers
Determined 06-18-2006 10:01 PM
Actually, the height with the ARP heads studs installed they way I described was nearly dead on. Let me try to upload the pictures again.
Thanks,
Alex
http://forums.pelicanparts.com/uploa...1150693303.jpg
Wayne 962 06-18-2006 11:52 PM
Try shortening your image filename.
-Wayne
Determined 06-19-2006 06:56 PM
Thanks Wayne!
Let me try uploading again, I think the pics tell a lot.
Best Regards,
Alex
http://forums.pelicanparts.com/uploa...1150768506.jpg http://forums.pelicanparts.com/uploa...1150768537.jpg http://forums.pelicanparts.com/uploa...1150768558.jpg
Jeff Alton 06-19-2006 10:06 PM
looking good, That is about how mine looked.
Cheers
