3.2 SS taking shape
Hi guys, finally got organized enough to start my engine build. Standard 3.0 crankshaft was machined at Ollies- it looks too good to hide inside the case! Tightening the rod bolts was the SCARIEST thing i have ever done. I put together a tool to mount my dial guage and got the stretch measured @ 0.006 inches. The complete crank is now sitting on my desk- taunting me to find the time to continue the build...
'79 SC-Silver Arrow 3.2ss-twinplug-EFI |
3 restos WIP = psycho
Carillo rods, eh? Why'd you go Carillo over another brand? I have heard the different pitches, but am always curious about decisions when dollars change hands. I was going to go Pauter, but the Carillos are lighter.
That crank looks freaking amazing! What was the $ damage if you don't mind me asking? As you can tell, I am just a few steps behind you on a similar course. Can we get pics of the tool you used to do the rod bolt torquing/stretch measurement?
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
3.2 SS
Hi Kenik,
I didn't exactly choose the rods- i bought someones race car project which included a new set of Carrillos. They are beautifully made and as you say very light. Machining on the crank came to a little over $700- if i was going to build another engine i don't think i would afford this expense. However the crank is now as light as a 2.7... The tool is made up of some parts we had in the lab which will support a dial guage. I'll take a pic soon Brett
Seven hundy, eh? I assume that included a zero balance factored into the fantastic knife-edging they did? Did they do anything else?
Might I say that the crank work you did will pay huge dividends. I seem recall an unfinished 3.2SS project for sale on Pelican awhile back. Is this the one?
(the shotguns)
That crank/rod statue looks like it belongs in a glass case!
PUUUUURRRRDY!!!!
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
Paper Member
Your comments remind me of when I bought some JE's a few years ago and my wife said, "You're going to hide them in your engine?"
Enemy of the State Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it. |
Super Moderator
Dave,
I felt the same way! They're way too nice to hide inside the engine and coat in oil...
3.2 SS
Hi guys- I have to look at the crank and rods everyday, arrgh...
Did someone mention J &E's...The cylinders are EBS 98mm. Rings went on OK, and the psitons slipped in without any problems, phew
Super Moderator
Engine BLING!
Looking Good
Author of "101 Projects"
For those not in the know, the crankshaft in these pictures has been "knife-edged", which is used to reduce air friction inside the case as the crank turns. Not really necessary for street engines, but good for race engines, when you're trying to extract every last ounce of horsepower...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Hello, all.
The crank also looks to have had an extra oiling hole drilled in it, and a groove round the main journal to increase rod oil flow ate very high rpm. This requires special main bearings, and probably bigger oilways in the block.. Kind regards david |
