3.0 SC Time-serts size question
I have decided to use Time-serts to fix my loose head stud problem. Does anyone know the correct size time-sert kit to use to get the full thread length? part number?
HI try this site www.wurth.co.uk then type in time-surt should give you the full list+spairs.
the insurt length is 20mm. if it is for the head studs you will have to mod' the resess tool to clear the cylinder base spigot regards mike
Regards mike 1983 911 SC sport, 1982 mini city Last edited by MBEngineering; 06-22-2006 at 04:47 AM.. |
3 restos WIP = psycho
Time Certs, from everything I can read, are old tech and inferior to Case Savers due to the fact that they are installed with an interference fit and can thus come loose. Why are you not using the Case Savers instead?
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Try not, Do or Do not
Locitite sleeve and bearing mount (green) will most likely cure a very slight wiggle.
A Timesert will work fine in an aluminum case. CaseSavers are old technology. They just happen to work the best in a mag case. The reason they work better in mag case is that they come in many different size (10mm) and they have varying thread pitches on the od. The CaseSaver is technology left over from the Type I bug days. They have been around since the late 60's.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 06-23-2006 at 04:56 PM.. |
