-   -   miss shift at the Glen? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/290323-miss-shift-glen.html)
Alex973 06-26-2006 07:31 AM
Hello folks need your help, i missed shift at the Glen this wekend
any ideas? rebuild the top end or someone could sell a 3.0L top end for sale?
regards
Alex
had lot's of fun with the folks at the Glen aside the trouble with the car:-(
kenikh 06-26-2006 08:20 AM
Pull the motor and get a look at the valves and pistons crowns. That's where to start.
Alex973 06-26-2006 08:32 AM
thank you, is it possible i could just buy top end for 3.0 and bolt on?
alex
kenikh 06-26-2006 08:36 AM
Yes, it is. By top end to you mean towers, heads and P/Cs? Or just heads?
MBEngineering 06-26-2006 12:25 PM
HI was it a over RPM or engine failed, either way at least change the rod bolts, good luck
regards mike
ChrisBennet 06-27-2006 03:13 AM
alex
If you want to turn it around in time for your next event or something, it only takes a few days to get the heads done. I use Atlantic Enterprises in NJ (856 589-5577).
-Chris
Henry Schmidt 06-27-2006 06:49 AM
regards mike
Mike couldn't be more right.
Even if there was no piston the valve contact, an overrev is always a good reason to replace rod bolts (ARP can be reused) and rebuild the rods. Obviously replace the rod bearings.
Many years ago I allowed a customer to talk himself out of doing the rods after an overrev and after the engine was reassembled top end only he got 87 miles before a catastrophic failure.
Another customer with a two liter vintage racer overrevved his engine on Saturday pulled the valve cover that night, did a leak down and adjusted the valves. Good leak down and him racer buddies told him he could run it (against my advice) and on Sunday by midday he had a "magic window" in his case.
Alex973 06-27-2006 08:16 AM
Thank you for all your wisdom and advise, Thank you Cris for the lead and also Mr. Schmidt.
regards
Alex
