-   -   Dang It!!!!!!!!!!!! I twisted it (http://forums.pelicanparts.com/911-engine-rebuilding-forum/290412-dang-i-twisted.html)
johncmng 06-26-2006 01:54 PM
I twisted the hard oil line that is under the motor.
Dang it!, @$))(#$* and $$.
Can I use after market steel braided oil line?
I found a website http://www.paragonperformance.com/
Will those do or I better stick with the OEM.
PPilot 06-26-2006 02:45 PM
There is absolutely no functional reason braided will not work perfectly, as long as ends match, these are used in aircraft and racing applications...
johncmng 06-26-2006 04:03 PM
Great! With that said. Anyone here use steel braided oil lines?
Where did you get yours?
Thanks in advance
David 06-26-2006 04:45 PM
www.batinc.net
shbop 06-27-2006 12:24 AM
If you have the crimping tool, or access to one, they are very easy to make, and it's hard to beat the look of braided stainless lines.
