-   -   Brain dyno - trying to decode lobe centers and durations into HP (http://forums.pelicanparts.com/911-engine-rebuilding-forum/291139-brain-dyno-trying-decode-lobe-centers-durations-into-hp.html)
kenikh 06-30-2006 10:55 AM
I was just looking at a post on the Early S Board from a 906 engine owner. His car, running the same ‘69S heads as mine, using 906 cams, returned 210 HP on a dyno at 7800 RPM. My car is a 2 liter S that is being seriously tarted up.
I just bought some cams from camgrinder that met the drivability and rev range characterstics I gave him to work with. I am trying to use the brain dyno to figure out how much power to expect on top of the power band. I am not concerned about anywhere else in the rev range, as these cams are going to make significantly more HP and Torque sub-4000 RPM than 906 cams due to having very fast ramps.
Looking at the 906 cam, it generates significantly less lift than the custom DC44:
906= .463"I/.460"E
DC44= .490"I/.490"E
The 906 runs on a lobe center of 96 vs. the 102 of the DC44.
The 906 runs durations of:
290I/262E @ .040" and
283I/255E @ .050"
The DC44 runs durations of:
264I/254E@ .040" and
258I/248E@ .050"
Since top end HP is essentially a function of how much and how fast you can get air into the motor, I am wondering if anyone with more experience than me has a guess as to how much HP this motor is going to make at 7800 RPM on the DC44 cam, using the 906 info as a baseline. A real dyno run will come at a much later date.
Thanks!
kenikh 06-30-2006 10:59 AM
BTW, assume the same CR.
Steve@Rennsport 06-30-2006 02:41 PM
Kenik:
Before I'd venture an educated guess, more information is required.
Heads: stock '69S ones?
Stock-type heat exchangers?
Muffler?
'69 MFI?
Twin-ignition?
CR?
Answer all that and I'll offer something based on similar combinations.
kenikh 06-30-2006 03:39 PM
Stock HEs for now; eventually going to headers by George
Muffler is stock for now; something VERY special later (assume megaphones, coupled with the above headers)
'69S MFI
Twin plug: 10.3 - 10.5:1
Feel free to email me on the "muffler" if you are curious. :D
Steve@Rennsport 06-30-2006 03:57 PM
George's headers are too short for these motors,...... :)
Megaphones without a crossover kills bottom and mid-range manners. The effects are exacerbated by longer duration cams.
Any other internal mods? Boattailing? Knife-edged crank?
kenikh 06-30-2006 04:01 PM
George's headers are too short? I was assuming he could make them to spec. Let's assume a crossover pipe; since the new exhaust is going to custom fabricated, all is possible.
I wasn't planning on boat tailing or knife edging this motor.
Steve@Rennsport 06-30-2006 07:59 PM
George makes one length in these 1.5" headers but he does do a custom version for us, exclusively. You can use his standard one, but you give up some mid-range power.
All in all, I'd expect somewhere around 190-195 HP if you have good flowing heads.
kenikh 06-30-2006 09:52 PM
Sounds like I will be buying my headers from you then. :D Thanks for the feedback. It is actually almost exactly what I hoped.
Steve@Rennsport 06-30-2006 10:27 PM
Let me get you a copy of the dyno overlay that shows the HP/torqu differences between the short (normal) and long-tube headers on some 2.0 litre race motors that are configured closely to what you are building.
You'll see what I mean,....:)
kenikh 06-30-2006 10:34 PM
Sweet! I can't wait!
davidppp 07-01-2006 06:48 AM
This matter of headers is interetsting, Steve.
I'm assuming you are using 1 1/2 inch pipes?
I wonder whether , with somewhat more rev-oriented cams, eg DE 60's, 1 5/8 with shorter pipes may give a little more in a racer?
Also must decalre an interest!
Kind regards
YTNUKLR 07-01-2006 12:35 PM
must...subscribe...:D
Steve@Rennsport 07-01-2006 03:02 PM
Kind regards
Hi David:
Yessir,....these smaller engines; 2.0-2.2-2.4, prefer 1.5" pipes.
Larger diameter pipes simply kill the low & mid-range power without a payback on top (above 6.5K) and they generate uneven A/F ratios which can be observed in the AFR plots. The torque curve mirrors the A/F curve so as mixtures vary, so does torque.
IMHO, larger but shorter primaries do not pay dividends.
There is a possibility that some kind of stepped header might work pretty well too, but that would require some detailed and lengthy dyno tests to prove that. :)
davidppp 07-02-2006 01:43 AM
Great advice, Steve.
I will pm re headers.
Kind regards
