Smart quod bastardus
fredmeister's Avatar
best oil cooler for 79 turbo 3.3
Looking to replace the loop oil cooler on a 79 3.3 turbo.
What is the best aftermarket cooler set-up without replacing the front valence to install a front mounted system?
What type of oil temps to expect with this system under DE event conditions?
Old 07-21-2006, 03:04 PM
BReyes's Avatar
Have you considered the carrera oil cooler?
Regards,
Bernard
Old 07-29-2006, 08:24 AM
You could buy a Setrab cooler and fit it in the RF Fender well, probably just have to change out some fittings, and of course come up with some new mount points.
Brian
Brian Keith Smith
Old 07-29-2006, 09:04 AM
Wo ist die Rennstrecke?
DonE's Avatar
I use a dual pass Fluidyne cooler mounted in the passenger's side wheel well. I also ran -12 line throught the stock bumper to the driver's side and installed a single pass Fluidyne cooler. Together, they are more than enough - the passenger side dual pass by itself is enough for street use if properly plumbed and "sealed" (forcing air to pass through it). They also add about 3 qts to the oil capacity.
Old 07-29-2006, 01:23 PM
Jk369's Avatar
DonE,
What is the model number of the Fluidyne cooler?
'80 SC 911
'67 Chevy SS Nova - Supercharged
'99 GSXR track only, '99 Superhawk
'05 Toy PU - daily driver
Old 07-31-2006, 09:55 AM
