-   -   Cayman/997 engines (http://forums.pelicanparts.com/911-engine-rebuilding-forum/291815-cayman-997-engines.html)
blue72s 07-04-2006 04:35 PM
Cayman/997 engines
As you may know, with the exception of GT3, all Cayman and 997 engines have a bottom end that is not so good. Seal problem at the rear end; integrated semi dry sump; etc.
If a customer gave you a job to change the bottom end of his engine - say Cayman, what would you do?
TIA
kenikh 07-04-2006 08:25 PM
I'd drop in a GT3 mill.
Steve@Rennsport 07-05-2006 12:47 AM
Interesting question that requires some clarification,...:)
Given that the only transmissions that can bolt up to these engines are the 996-997-Boxster-Cayman ones, what would be the purpose to change the bottom end (short block)?
Improved durability?
Repair or overhaul?
If you were trying to do something different in a Cayman, your only choices would be something like the X-51 3.8 engine with the Cayman gearbox, or an outright replacement with a GT-3 engine AND transmission (mounted upside down). The latter option would not be easy to do.
blue72s 07-05-2006 09:20 AM
What is a mill?
Repair or overhaul?
Improved durability. For tracking/racing (8,000rpm). Also, I'd want dry sump.
Wow, I had no idea about this. I thought a GT3 engine can bolt up to a Cayman gearbox.. Thanks for this.
kenikh 07-05-2006 09:59 AM
"Mill" means "Motor".
As far as bottom ends go, I am not even sure that the bottom ends on the water cooled cars are swappable. The GT3/GT2 motors are based on modified air cooled cases with water cooled top ends. I am not sure that the top end of a Cayman/996/997 would even bolt onto a GT3 bottom end.
blue72s 07-05-2006 06:27 PM
Can't an adapter be made to make the 6-speed Cayman gearbox to bolt up to a GT3 engine?
What is the difference between the Cayman gearbox and the GT3 gearbox?
Steve@Rennsport 07-05-2006 06:45 PM
FYI,....The 996-997-Cayman-Boxster engines have NOTHING at all in common with the GT-3-GT-2-996TT-997TT engines.
Two totally different and separate engine families. :)
Same for the transmissions used in these various cars; they are totally different. :)
Nothing is interchangable so if one chooses an engine from one family, you MUST use the corresponding transmission. A custom adapter could be made, but that creates positioning issues for many components and the GT-3 transmission must still be converted for upsidedown operation.
Personally speaking, I'd not go to all the trouble unless I was going to use the GT-3 engine. :) :)
blue72s 07-06-2006 08:20 PM
Why does the GT3 transmission have to be turned upside down?
Steve@Rennsport 07-06-2006 09:35 PM
Because it turns the wrong direction for a mid-engined car and the ring gear cannot be moved to the other side,...:)
Wayne 962 07-07-2006 12:26 AM
I would just buy a GT3 - they are about $80K these days. 996 Turbos can be had for $65K!
-Wayne
blue72s 07-07-2006 09:15 AM
Whoops. Thanks.
Did 914/6 had to do the same with the 915 transmission by turning it upside down?
Steve@Rennsport 07-07-2006 08:23 PM
Whoops. Thanks.
Nossir,..there is room inside the 915's final drive case to swap the ring gear to the other side.
All of the G-50's must be turned upside down and the oiling system modified to suit with a pump & cooler.
blue72s 07-07-2006 08:51 PM
How about a custom ring gear & pinion (from a race transmission manufacturer), identical to the original r&p but in opposite direction? Would this work?
Steve@Rennsport 07-07-2006 10:00 PM
How about a custom ring gear & pinion (from a race transmission manufacturer), identical to the original r&p but in opposite direction? Would this work? [/B]
I really think you'll need a matched pinion shaft to make that durable. I've never had any long-term luck using mis-matched R&P's in these cars as Porsche goes to great measures to match each & every ring & pinion gear to each other for lowest noise and maximum durability.
The R&P are THE most stressed parts of Porsche gearboxes due to the extreme hypoid angle on these parts and the shearing moments experienced by these two parts. Neither lasts very long when you use mis-matched components.
JohnJL 07-08-2006 11:08 PM
Local race-fabrication shop did a 90-minute walkthru of their GT3/Boxster amalgamation at the last PCNSW meeting. In the end, it had more GT3 parts than Boxster. THe owner was happy, but both owner and shop admitted there was more GT3 and it wasn't very cost effective.
They did indeed flop the transmission, and there was diffuiculty fabbing the bellhousing and suspension bits. Also, the GT3 engine needs all the supporting electronics, so in fact the dash instruments were also GT3.
Very cool project tho.
blue72s 07-10-2006 12:13 PM
Cool. Which exhaust system did they use?
blue72s 01-23-2008 07:20 PM
Old thread I know but I was just thinking that turning the GT3 gearbox upside down (for Cayman) might not be a bad idea afterall. One of the advantages is that, with the inverted gearbox, the engine location could be lowered, thus lowering the centre of gravity. This should be possible because, unlike the Cayman engine, the GT3 engine doesn’t have a wet sump tank beneath the crankcase so the dry-sump GT3 engine can go further down in the engine-bay until it touches the aero undertray.
Another advantage of inverted gearbox is that it might result better half-shafts angle thus less wear (and less heat) on the bearings of the CV joints.
As you may know, many racing cars run inverted gearboxes for the above mentioned reasons.
Why didn’t Porsche do this with the 914/6 and 916?
Do you agree? Thoughts? Rants?
petevb 01-23-2008 09:54 PM
Hmm. The gearbox for the water cooled cars is a weak point and is virtually un-serviceable. The Koni Challenge cars are forced to use it (and the wet-sump motor) for rules reasons, and they go through them with regularity. Far more often than the motor, in fact, which tends to last fairly well under race conditions.
That said, both the X51 motor and trans are cheap- you could replace them a number of times for the cost of the GT3 motor and trans. And the motor does last better than you'd expect under race conditions, and it's lighter than the GT3 motor... So the smart thing is probably to get an X51 3.8l and be happy.
If you can't do that, you might look at a GT3 cup or World Challenge motor (track only- forget emissions). They are true race motors, and the motorsports ECU avoids some of the drive-block and other issues you'd see with a GT3 street motor. Some GT3 Cup years will run fine on pump gas, they are available on the used market, and you can bolt them in without the drive block and other issues. Figure ~410 hp depending on the year, ~$25k-$40k. Also figure ~$25k rebuilds every 80 race hours on a cup motor (actually rebuilt less often than a high strung air cooled motor, and similar to how long a street GT3 motor would last in race conditions). WC spec will add ~40 hp, 10k on the rebuild cost and cut the rebuild time in half.
Cost wise you'd end up so far ahead with the X51 motor that I don't think you could justify the conversion as a one-off. If you were making a conversion "kit" to get the GT3 motor in to the Cayman, and could spread your cost, it might be almost bare-able instead of massively painful.
The lower CG seems possible, but inverting the GT3 gearbox (already designed to put the motor as low as practical) might result in the motor being too low. It's a minor factor in any case- if you've got the extra clearance it's better to leave the motor where it is (even with the under-body) and drop the whole car, IMHO.
-Pete
blue72s 01-24-2008 07:01 PM
Thanks man. :)
AFAIK Porsche is using various gearbox manufacturers for the watercooled cars - Aisin for 997, Getrag for 987S 6-speed, and and I think Aisin or VW for 987 5-speed. Are you saying all of them are un-serviceable?
Is the 987S Getrag still no where near as good as the GT3 Getrag?
By how much?
Where is the used market?
When you say 'drive block', do you mean PSM, TC? None of the street GT3 years have PSM but the Mk 3 does have TC.
petevb 01-24-2008 07:31 PM
I don't know the details, but I understand the tools to tear down/ rebuild the 997S gearboxes are not readily available, and they (the synchros especially?) are not nearly as strong as the GT3/ cup/ turbo units. Thus the race teams replace them entirely at significant expense (I've heard as often as every other race weekend under extreme use). This info was current as of a couple years ago, but I believe it's still the case.
By how much (lighter)?
I wish I could answer that better, but I've had a hard time coming by the data. The GT3 street motor is probably ~50 lbs heavier vs the 997 street motor. The GT3 cup motor is lighter than the GT3 street (no variocam, etc). For reference, the dressed 997 street motor lists at 444 lbs, while a 993 motor weighs 511. The GT3 street motor has some lighter components than the 993, but adds variocam and water, and is thus in theory heavier...
Race sites- the grand am board, etc. PMNA keeps tabs on motors for sale, but don't tell them you're putting it in a street car. Sometimes the back of Pano or Rennlist...
Drive block as in the anti-theft system that insures the engine stays with the car. Can be tricky to defeat.
-Pete
blue72s 01-25-2008 07:46 AM
I didn't know about the variocam delete. Learn something new everyday. Anything else? For what reason they don't run variocam?
Another question: Which years Cup engine is the most liked?
J P Stein 01-25-2008 08:32 AM
Gee, Pete, you sure seem to know a lot about the GT3 electrics.:D
petevb 01-25-2008 08:50 AM
Regarding the VarioCam, I think they drop it partly because they don't need low-end torque as much (they are close geared and spend time in mid-upper revs only), partly because they don't need a mild cam to help pass smog, and partly due to weight/ complexity. The 997 cup motors are listed ~15 hp down on their street counterparts because of this, though in reality, especially taking "area under the curve" into account, they are roughly as powerful.
In terms of the year, most people argue either for an early or late motor, with the mid years seemingly slightly less loved. Early ('00-'02, I think) ran lower 11.5:1 compression, solid lifter cams, and lower revs. Thus they are easier to run on pump gas, they generally have lower oil consumption, and time between rebuild *might* be longer. The middle motors switched to longer rods, different rod-end bearings and hyd. lifter cams; power and oil consumption went up- these are generally not as favored. The '05s-'07s had some small fixes, and power was uprated to 400. I believe they are also slightly lighter than the early motors, though compression and oil consumption are up slightly.
I understand that the '08 motor dropped the VRam style 2 chamber intake manifold and bumped compression up further to 12.5:1, and finally got a decent exhaust manifold. This should make it lighter still, and it's rated at 420 hp, so it's probably the one to have but it's expensive...
I'm told the '00-'02s generally dyno in the 335-340 rwhp range, while the late ~'06s dyno in the 365-370 rwhp range. Not sure what the '08s dyno at, but I'd guess ~385. All pre-'08 cars have a poor exhaust manifold design- ~20+ hp can be found by fitting a proper equal length manifold.
All of this info comes as word of mouth- I haven't found the big spec book that lists all of this stuff...
-Pete
petevb 01-25-2008 08:53 AM
Who, me? Just interested, is all... ;)
blue72s 01-25-2008 04:52 PM
Nothing wrong with longer rods (better rod angularity and piston dwell).
What was wrong with the rod bearings of the middle motors?
Could hydraulic lifter cams be reverted back to solid type?
Could this be retrofitted to pre-'08 engines?
petevb 01-26-2008 08:54 AM
No idea. Maybe they just were not improved enough to cope with the extra revs, maybe it's an oiling issue, maybe it's just a rumor...
Maybe, but I doubt you'd want to. The lifters were carried over from the 959, I understand. What's often done at rebuild time is an update to a later motor spec. So you send in your '03 and say you want it built to '06 spec, spend a little extra money with the motor to PMNA and get the parts swapped out. It's not cheap, but having a PMNA rebuild is valuable in itself. PMNA keeps record of what's done, often provides an unwritten warranty, etc- mess with the motor yourself and the value is greatly reduced. Also if you mix and match by yourself you'll have trouble tuning. Most people outside of PMNA can't tune the bosch motorsports ecu, so the option there is to go Motec, etc...
Of course, and there are lots of other exhausts that make even more power at the cost of torque, etc. The early grand-am spec headers are cheaper and might be better depending on your application. I'd plan to swap the early cup headers and exhaust as a first priority- lots of power locked up there, and it's loud. You can also find a Grand Am spec single plenum intake (like the '08) and fit that, again at the cost of a little low-end.
If you want to go that far, however, you can just get an early grand-am spec motor and run it on good gas. The later ones had 2 ring pistons (vs 3 in the cup motors) that wear faster, but the early ones were quite similar to the cups. You can extend the TBO by cutting revs a little if you want. PM me if you want motors/ prices- I can point you to some.
-Pete
