valve cover gasket replacement
I thought I might get a few more hits over here....
Do the valve cover gaskets only go on one way? The exhaust side gaskets appear to have a bead of silicone...and and I assume I should have the printed letters on the outside. In regards to the intake side...should the graphite side face outwards...? I can't seem to line up the intake gaskets with the print facing the outwards, so I assume the graphite side face outward....
86' 911 Carerra
Old 07-08-2006, 10:09 AM
They will only go on one way. If you turned them over they wouldn't fit the bolt pattern or the pattern on the cam tower/valve cover.
Old 07-08-2006, 05:30 PM
Thanks Eagle...I went back to the garage after posting and looked at each orientation. I could see they only went one way, and that was good enough for me...thanks for the response.
86' 911 Carerra
Old 07-08-2006, 07:08 PM
