Rocker arm shafts. Torque dry? or Wet??
How do you guys assemble the hydraulic lifters. Do you torque the 5mm allen bolt of the rocker shafts to spec regardless of oil on the threads, or do you clean them free (brake cleaner) of oil to get a dry torque? 993tt engine
Torquing them tonight. Thought I check to avoid emabarrassement (and cost!) later.
do you put anything on the threads??
Old 07-12-2006, 07:10 PM
