-   -   fan assembly (http://forums.pelicanparts.com/911-engine-rebuilding-forum/293501-fan-assembly.html)
Alan L 07-14-2006 10:59 PM
fan assembly
I'm busy putting my SC together and up to assembling my recond alternator . I have two different washer/spacer things that go on the alternator shaft. One I can find in Waynes book and goes behind the final nut. This looks like a stepped spacer. The other one is a dished spacer. If it was about 10 th smaller in diam it would fit into the bearing housing on the alternator, behind the fan.
Other than that, I can't find a home for it. Does the fan just go straight down on the bare shaft?
Alan
greg bradbury 07-15-2006 06:24 AM
As far as I know (my set up) the fan slips straight on to the keyed shaft then shims then the v belt half then shims (total shims must be 6) then a cupped washer over the shims then the nut.
