-   -   Help Identifying 2.0 P & Cs (http://forums.pelicanparts.com/911-engine-rebuilding-forum/294438-help-identifying-2-0-p-cs.html)
Henry Carraro 07-20-2006 08:13 AM
I have recently come into possession of a set of Mahle pistons and cylinders as well as a set of heads. I am particularly interested in identifying the pistons and cylinders.
I was told by the seller that he thought they were out of an early 2.0 liter S motor. They appear to be Mahle cylinders. They are aluminum with steel sleeves. There are 6 cooling fins per inch. There is a part number on one side of the piston and it shows to be 80 ZD 3.
The pistons are also aluminum and inside the piston I can barely make out a part number 80P266.
Aside from a very small ding on the top of one piston, (outside the valve area) the entire set appears to be in very good condition.
Thanks in advance for your help.
http://forums.pelicanparts.com/uploa...1153408326.jpg http://forums.pelicanparts.com/uploa...1153408376.jpg
davidppp 07-20-2006 10:17 AM
Yes It may well be an S piston 1967-68...from the valve pockets.
A shot inside it will tell us if its forged.
Kind regards
