Wax or Crud underneath the car???
As I started to remove the motor from the car, I notice there were a coating of wax of some sort underneath the entire car and all over the tranny. Anybody know what this stuff is? Should I take it off? If so, what should I use to clean it? Will a power washer do?
85 Carrera Thanks John |
Sounds like somebody sprayed undercoating of some kind ..removal with an appropriate solvent will take a little research and careful experimentation...I would just leave it, probably put on in a northern clime to protect from salt!!!
Re: Wax or Crud underneath the car???
cosmoline
...And the cosmoline helps protect magnesium parts (like transmissions and some engine cases) from corrosion.
Mine had dirt/oil combination that looked like a "wax" or coating of some kind. A brass-bristle brush, Simple Green and a power washer cleaned it all up but made a mess of me and my clothes! Wear goggles and protective clothing!
| All times are GMT -8. The time now is 12:38 AM. |
