-   -   Tips on valve guide removal (http://forums.pelicanparts.com/911-engine-rebuilding-forum/294900-tips-valve-guide-removal.html)
SteveCarr 07-23-2006 05:49 AM
Yesterday I removed all of the valve guides from the cylinder heads from my 1985 930 Turbo. I did it like this.
I have a special drift that fits the valve guide that I made from 1/2 inch steel rod. I made this on a lathe about 20 years ago when I did my last engine re-build on a 911.
After de-greasing all six heads I put them in my wifes lovely convector oven and set the temperature to 230 degrees C.
After "cooking" them for approx 45 minutes I took each head from the oven and placed it on a peice of wood on the kitchen floor.
I carefully used some wet kitchen roll to poke down the centre of the guide to cool it a little then I used my special drift and a 4lb lump hammer to remove the guide.
Each and every one came out with no problems or damage to the heads.
When I fit the new guides I will put the new guides in my freezer overnight then heat the heads in the oven again then use another drift with a collar on it to insert the new guide to exactly the correct depth.
When I get my digital camera back I will post some photographs of the drifts I made.
I hope that this information is useful and if anybody has any other tips or advice it would be nice to hear.
Regards
Steve in the sunny UK!
neilca 07-23-2006 08:04 AM
Steve,
I just put new guides in my heads. I used dry ice to chill the new guides and heated the heads to 400F. Went in without a hitch. The dry ice will chill the guides to a lower temp then the freezer.
Good luck,
neil
davidppp 07-23-2006 11:20 AM
Hello, Steve.
I like to drill them guides first: 12mm is good..I believe this allows them to collapse a little thus reducing the broaching effect in the head..I leave the last 1/2 inch undrilled to seat the drift on and drive them out cold..
Kind regards
Henry Schmidt 07-23-2006 11:35 AM
If you do enough heads you will find that pushing the guides out will only work if the guides have very little wear.
What we do is run a 10 mm tap in the spring end of the guide and then screw a 10 mm bolt in the threaded hole 15-20 mm.
Next you push the guide out with the appropriate valve guide tool by pushing on the bolt.
If you just beat ( wack-it, wack-it, wack-it) on the valve seat end of the valve guide you may get lucky on a few but eventually you are going to mushroom the end and as the guide moves it will split the boss on the inside of the port.
SteveCarr 07-23-2006 02:46 PM
Hi Henry,
I did not make myself clear in my first post.
I used a drift from the valve spring end and NOT the valve seat end. My exhaust valve guides were shot so it would have been impossible to get them out by trying to drive them from the valve seat end as you rightly say.
Best Regards
Henry Schmidt 07-23-2006 03:26 PM
That won't work with most valve guides. Most valve guides have a lip or collar to seat the guide again during installation.
The racing guides have a 5-6mm lip.
rvanderpyl 07-24-2006 08:07 AM
Just put your drift in the freezer. That is how the small aircraft engine rebuilding place I worked at for a few summers did it. They also had a real nice fixture that held up to 8 cylinders in a steel plate with holes cut out to seat the cylinders, it was fixed at both ends so it could be flipped, and then they had gas torchs that heated each cylinder up, the engine guy would throw all the cylinders on the fixture, fire up the torches and 10 minutes later turn them off, flip the cylinders over, grab a handul of drifts out of a freezer and knock each guide out. Did a very similiar thing to put the new ones back in. He then used the same fixture to hold the cylinders as he reamd the guides to size, cut the valve seats and and then honed the cylinders. He used to redo a complete set of 6 cylinders in about an hour.
cgarr 07-24-2006 08:28 AM
If you thread and plug one end as Henry does, that works great but I also drill out 90% of the old guide and it pushes out real nice. No heat or cold needed..
Henry Schmidt 07-24-2006 08:53 AM
It is an extra step but it does help.
If you have the correct size core drill you are ahead of the game.
SteveCarr 07-24-2006 03:05 PM
It seems that running a drill down the old guides to weaken them is popular but I was wondering if this is difficult to do in case the drill grabbed?
If the guide has a lip or collar then you are of course right Henry you can't drive it out like I said. My technique worked on my first 1978 3.0 911 SC for the old guides and the new ones and it will also be OK for my current project but I guess looking carefully at the type of guide that is installed is recommended before you try to get it out.
Nice tips and advice!
Regards
cgarr 07-24-2006 04:02 PM
A stock bit will grab real bad, I sharpen the bit real shallow, much like a bit used for plastic, otherwise it bites too hard
john walker's workshop 07-24-2006 05:39 PM
i use a step drill and drill 1/2 to 2/3 through the guide and then run it out with a special homemade bit in an air hammer. very gentle on the trigger! i always eyeball the valve spring end for a possible lip and run one out in the direction of the spring seat first to be sure there is no lip. sometimes it's hard to tell. ya don't want to run a lip through the guide bore! proper size step drills are available through baum tools. no heat necessary. never had any issues doing it this way. we used to get vw guides out with the thread tap and bolt method, but on 911 heads, step drilling is so much easier, and faster. mic the old guide and be sure the new one is the same size, or no more than a couple hundredths ofa MM oversize. spray the guide and guide bore with WD40 or the like and run them in. for installation i use the airhammer again, real light on the trigger, and a bit that fits the guide, with a fat washer slipped over it so not to damage the guide.
SteveCarr 08-03-2006 06:45 AM
Here is a photo of the old valve guides and the tools I used to remove them. You can also see the drift with the collar used to fit the new guides.
Hope this is of interest...
http://forums.pelicanparts.com/uploa...1154612624.jpg
shbop 08-03-2006 09:14 AM
Anyone using Neway cutters on their seats? Manual or air? Thank you!
cgarr 08-03-2006 09:30 AM
I used the manual cutters for both 2.7 and 3.2 heads, worked great #642 #272 and the 9.0mm pilot
john walker's workshop 08-05-2006 11:11 AM
step drill to bore about 1/2 way through, the long bit to run them out, and the bit with the washer to install. no heating or cooling needed.
http://forums.pelicanparts.com/uploa...1154801354.jpg
tony77targa 08-18-2007 02:20 PM
anyone point in the direction to buy a step drill bit online like the one in John Walkers post above... Ive searched for about 4 hours now and ready to give up....
Thnaks
Tony
shbop 08-18-2007 04:13 PM
Go to Baum Tools and type "step drill" in the search box. It will pop right up.
tony77targa 08-18-2007 04:19 PM
Thanks John ... I tried that and am getting nothing ... I must be on the wrong site or something... care to post a link???
Thnaks
Tony
tony77targa 08-18-2007 04:46 PM
Hey John I found it ... thanks for the help ... much appreciated... Tony
shbop 08-18-2007 04:51 PM
Glad you found it. I went back to try and get a link for you, and couldn't find it. Finally did, but I was starting to think I was hallucinating.
tony77targa 08-22-2007 03:29 AM
Called Baum tools to oreder the step drill today and they dont carry it anymore ... anyone else find a supplier ?? Mcmaster car has them but not in the exact size that John mentions...
cgarr 08-22-2007 11:13 AM
I chucked a bit up in my valve grinder and made one, you might do it on a bench grinder too..
shbop 08-29-2007 07:26 AM
Thought I'd revive this thread. Baum tools no longer sells these tools. It seems the only way to get a driver for valve guides is to make one, or buy the Neway kit. Anyone have another source for these? I bought the replacement guide-driver from Snap-On, ph 86, and had to machine it down, in order to work. Obviously not the right tool, but all he said he could get. I'm also looking for the Klien guide reamers. Anyone? Thanks in advance!
bpu699 08-13-2017 04:35 PM
Just found this thread searching valve guide info...
Really interesting...
Do a lot of folks remove and replace their own guides?
If one did this, would the valve seal in the original seat?
Amazing what folks have done on their own!
Trackrash 08-13-2017 08:56 PM
I just finished doing my own heads. I have done this several times over the years. It helps that I have had friends with the equipment and experience to guide me.
You will almost never have a new guide that will not have to be reamed to properly fit the valve stems. This requires a special reamer. The fact that the old guide and valve were worn in together will require the seat to be re-cut to match the new guide.
There is almost no point in not restoring your valve seats if you have gone this far.
You should not consider doing this yourself, unless you have done it before and have the proper tools.
BTW, I find it amazing that the OP was successful with his method.
Mark Henry 08-14-2017 05:27 AM
^^^ Agree.
I don't just buy tools, I make every tool that I realistically can.
Saves a boat load of cash, I can make tools that are not available and I understand the job that much better.
My shop made tool list on VW and Porsche is quite extensive.
bpu699 08-14-2017 08:26 AM
Originally Posted by Mark Henry (Post 9699174)
^^^ Agree.
I may need to make a new thread :).
I made my own CAM removal tool, somewhat similar to a commercial one. I really needed the tool, didn't want to wait a week...
Went to Harborfreight bought the following:
1) Large impact socket (? 1 3/4)... 4$
2) Impact extension, 2 inch. 4$
3) Old screw driver. 0$
4) Old 13inch socket with 1/2 inch extension... 0$
Aligned the socked with the cam gear. Cut the screwdriver shaft, which is hardened steel, into 3 2 inch pieces.
Put the pieces into the sprocket holes, held on with a worm clamp used for hoses.
Welded on the pieces to the socked...
Welded on the extension to attach a breaker bar...
Now here is the totally nifty part where things just "work out."
The cheap harbor freight extension with a 13mm socket fit PERFECTLY into the large socket. The shaft fits PERFECTLY into the hole meant for the socket wrench.
Voila!!! Perfect tool, total cost 10$.
One cambolt came right off. The other one snapped the extension. So, used a larger diameter higher grade extension. Problem is, it wouldn't fit into the sockets hole. Put it on a drill press (don't have a lathe), ran a belt grinder against it to cut it down slightly, and it fit like a charm... I originaly tried to drill out the socket hole... that didn't work so well. Just chewed up the drill bits.
Will try to post pics later...
Would it have made mores sense to buy the tool? Maybe. But I can make it, so why not. :)
Mark Henry 08-14-2017 09:19 AM
Yep, I do it all the time.
One non-Porsche tool I made was for breaking tractor tire beads, about $750 to buy new, for a tool I may use a couple times a year. Made it from scrap steel and $25 in parts.
If some one starts a shop made tool thread I'll post some pic's. ;)
Trackrash 08-14-2017 09:27 AM
Yea, I won't bore you with all the tools I have made....
Back on topic, I thought I would share the method I used on my last build to remove the valve guides. Kind of a hybrid method.
I used a 10mm tap to thread the spring end of the guides. Then screwed in a 10mm bolt.
I used my press to push out the guides, after heating the heads, using a 1/4" socket extension, which fits in the guide. I pushed out the guides from the seat side. I supported the head using an appropriately sized deep socket positioned where the valve spring sits.
I didn't have to worry about some weird angled support or any damage caused by my air hammer or the sledge I have used in the past.
