Piston Oil Squirters?
In doing a top-end rebuild, is there anyway to force solvent through or clean the piston oil squirters without splitting the case halves? Anyway to test them to see if they are freed up?
I can't think of anyway to plug all the openings you'd have to plug. I wouldn't want solvent in my oil system either.
-Andy
72 Carrera RS replica, Spec 911 racer |
Banned
You will have to split the case, good luck, cheers, Ant.
I have got my case split but four of the squirters are blocked and I can't seem to force solvent down them using the pressure of the spray can. Any tips or good ideas would be appreciated.
Regards Steve |
Than My Track Schedule 1984 911 Viper Green Track Car - Parted out to fund 1993 BMW 325is Spec E36 Race Car |
Hi Dadofour I did and thanks for pointing me at it...
Regards Steve |
Super Moderator
Bottom line you'll need more pressure than a spray can will put out. 30psi I think is what opens then.
I never did get mine freed up. I ended up rplacing 4 of them. 3 wouldn't pass anything and one was very slow.
Case/Piston Squirters |
Thanks the thread you pointed me at is very interesting. I hope mine will blow through with compressed air...
Regards Steve Last edited by SteveCarr; 08-06-2006 at 09:57 AM.. |
