-   -   ITB's on a 3.2 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/296097-itbs-3-2-a.html)
1972_911T 07-30-2006 08:27 AM
ITB's on a 3.2
Is there anything to be gained from adding ITB's to a 3.2 with aftermarked EFI and better flowing exhurst, with no other internal mods except 964 cams? Engine already as ARP rodbolts so could anything be gained from rasing the RPM with this setup?
Thanks steve
Steve@Rennsport 07-30-2006 11:58 AM
Steve:
FWIW,......we installed our own tall ITB intake system on a totally stock 166K mile, 3.2 motor with SSI heat exchangers and Monty muffler. We used DTA engine management to tune the motor and got 249 HP at the crank.
The baseline runs with the OEM intake resulted in 217 HP so the gains were certainly worthwhile. :)
1972_911T 07-30-2006 12:16 PM
Do you think the use of 964 cams could further increase this?
Steve@Rennsport 07-30-2006 01:52 PM
Yessir,....that will help a bit, especially on top.
