Head stud tightening methods
I have searched this but couldn't find an answer. This is for a 3.2.
Factory manual says 11 ft-lb then 90 degrees, with no mention of reotorquing Wayne's book and several posts say two stages, final tightening to 23.5, with re-torquing after a bit of running. I followed the factory method - the nuts are considerably tighter than 23.5. Also, there is no way to re-torque later with the tighten then 90 degree method. To the best of my knowledge, when bolts are tightened by a stretch method (which essentially the factory method accomplishes) there is no need for later re-torquing. Properly installed rod bolts would be an example. So, what is the right thing to do? |
A few people recommend re-torquing headstuds. The rest of us and the factory recommend not.
-Andy |
I've always checked mine on new engines after a few hundred miles or so... Never had one that needed to be re-torqued...
| All times are GMT -8. The time now is 01:09 AM. |
