oversized valves
i have a 3.0l 930. how much bigger can i go on the valves before i need to cut the valve reliefs in the pistons bigger(stock 3.0 turbo pistons)??? I know the cam i'm using will make a difference but is there a size i can go to and not have problems?? Thanks in advance
Old 08-06-2006, 08:05 PM
beepbeep's Avatar
That engine has 6.5:1 C/R so with I guess you won't have problems with most "mild" cam designs (930, SC).
Otherwise, just bolt it together and turn it by hand while out of the car. You'll have to check deck height anyway so there is nothing to loose. Should it touch the piston (unlikely) you could just remove the pistons and notch them.
Thank you for your time,
Old 08-07-2006, 01:37 AM
