-   -   Source for turbo hoses (http://forums.pelicanparts.com/911-engine-rebuilding-forum/298311-source-turbo-hoses.html)
Tom F2 08-12-2006 04:49 AM
The connector hose to the throttle body for a 3.0 Turbo is NLA from Porsche. Our host doesn't list it either. Has anyone tried the aftermarket silicone hoses for this application? The original part appears to be a fabric reinforced neoprene hose. The dimensions are 40 mm i.d. x 80 mm long. This size doesn't appear on any of the on line sources for silicone hoses, either.
Any suggestions? Here's a photo. The hose is the stubby wide one, with the steel mesh screen in the opening.
http://forums.pelicanparts.com/uploa...1155383313.jpg
asphaltgambler 08-12-2006 07:31 AM
Google 'silicon hose'
There are a few co's that only manufacture silicon-based hose. Most offer temp and color choices in just about any size you need
Tom F2 08-13-2006 05:40 PM
I tried this, but I am not sure of who has quality stuff. Also, my need is for 80 mm, which is close to 2.125", and no one seems to have this size.
David 08-14-2006 05:35 AM
The silicon hose is pretty flexible. A 2" hose will probably fit. I might even have a piece lying around to try. I'll check tonight.
Tom F2 08-14-2006 05:43 AM
I converted the i.d. wrong. It is 3.150", which is close to 3.125", not 2.125". Sorry.
RarlyL8 08-14-2006 10:25 AM
The metric ID is 80mm. 3" might work if you lube it up good.
David 08-14-2006 10:53 AM
I may have a piece of 3" hose, I have alot of pieces left over from my current project. How long a piece do you need?
Tom F2 08-14-2006 11:37 AM
Thank you for this offer, but I don't want to trouble you needlessly. I think I can get this from turbohoses.com for reasonable $$. Does anyone have experience with this outfit?
David 08-14-2006 11:48 AM
I've yet to find any reasonably priced silicone hoses. They seem to be about $20 and up. If I have a piece, it's scrap for me.
David 08-14-2006 04:24 PM
I've got a piece of 3.125" ID, 3" long hose, do you want it?
Ken911 08-14-2006 05:22 PM
I just went down to NAPA and got some rubber hose couple dollars a foot or something like that
Tom F2 08-15-2006 02:45 AM
Thank you, I pm'd you my address.
Tom F2 08-20-2006 04:31 AM
Thank you to David (125shifter) I found that Samcosport has metric silicone hoses at the 80 mm size.
