-   -   Separating fan shroud and generator help (http://forums.pelicanparts.com/911-engine-rebuilding-forum/299838-separating-fan-shroud-generator-help.html)
johncmng 08-21-2006 08:11 AM
I'm having problem separating the fan shroud and the generator.
I have removed all the nuts from the back of the unit.
The ones that are on the edge of the bracket.
Am I missing a nut or two?
3.2 Carrera
RV Flyer 08-21-2006 09:53 AM
On my '78 SC 3.0 there were 6 (as I recall) nuts spaced pretty evenly around the perimeter of the shroud, all of them had to come off before the shround will come off. Of course, then you move to the next step: separating the alternator from the fan housing (hint: time for hammer and block of wood!).
David 08-21-2006 11:14 AM
Pull harder and wiggle it some. I don't think the bolts usually bind up, it's just a tight fit between the alt. housing and the fan housing.
herman maire 08-21-2006 01:24 PM
Just remember there is a ground from the alternator> case.... If thats not it it might be your wires are not loose enough... I had to feed the wires throught the shroud to get enough room to pull the alternator back cover and unbolt the wires.... Be sure your battery in disconected.
Good luck
john walker's workshop 08-21-2006 03:26 PM
hold the housing with both hands, fan side down, and firmly knock the edge of the housing a couple of times on a block of wood or several rags folded flat on the floor. turn it 180° and do the other side. repeat as needed. gravity and inertia will work for you.
johncmng 08-22-2006 07:32 AM
It worked!
Thanks to everyone for your help.
