-   -   3.0 to 3.2 Engine Rebuild (http://forums.pelicanparts.com/911-engine-rebuilding-forum/300065-3-0-3-2-engine-rebuild.html)
mbrown 08-22-2006 10:01 AM
When it comes to Porsche engine rebuilds, I'm a virgin! (I have rebuild other engines though).
I'm going to tackle a 3.0 engine rebuild over the Winter, since I have found one broken head stud.
I have a few questions that I would like you guys to answer:
1. The vehicle (1980 911 SC) has run 101,000 miles, does this automatically mean new pistons/cylinders? Or do I need to measure a few things before making that decision?
2. Can I easily increase the engine displacement? 3.2 L or larger?
3. If I decide to supercharge the engine, can I buy pistons to suit the lower compression ratio? Any ideas on the relationship between compression ratio/boost level and power?
Regards
Mike
vanwyk4257 08-22-2006 10:47 AM
Here's a thread you should read. Welcome to the board!
http://forums.pelicanparts.com/showthread.php?s=&threadid=245455&highlight=camsha ft
Eagledriver 08-23-2006 08:06 AM
100k miles is not that much for there engines. You may find the pistons and cylinders still within spec.
-Andy
