-   -   930 Rebuild (street only) (http://forums.pelicanparts.com/911-engine-rebuilding-forum/301047-930-rebuild-street-only.html)
pushing 930 08-28-2006 09:28 AM
After much thought, it is time for some upgrades for my 79 930. I am a regular reader of this forum, but this is my first post. I am planning to upgrade the head studs, tensioners, exhaust, cams, clutch/pressure plate, and turbo. The case will be split for a complete rebuild etal. I value the advice of fellow Pelicans that have gone before me. The car is a low mileage stock 79 930 that I drive almost everyday. No track or racing, just enjoyable street driving in the 2500-5000 rpm range. I am seeking some performance gain, but mostly peace of mind and day-to-day reliability. I would like to keep the car as "original" as possible. I appreciate your suggestions.
adomakin 08-28-2006 01:12 PM
Hi, congats on finding this place-you've just saved yourself a fortune and spent a fortune in one go! So your engine is a low miler thats not thrashed and in good condition? If there are no serious issues (i.e. broken head studs/low oil press/lots of smoke) and you get some good leakdown figs then I would advise some simple bolt ons to start with- straight forward stuff that will ease you into the vast ocean that is modifying 930 engines. you can expect some real good power gains and a lower spool up from things such as headers (B&B/GHL) K27 high flow turbo, bigger intercooler etc. all of which you could call 'weekend mods' and don't reqiure any serious modifications to install. If you want more then you could start thinking about pulling the engine out and tearing it down but if i were in your shoes I would go with bolt ons and enjoy it sooner! hope this helps
pushing 930 08-29-2006 07:37 AM
Adomakin, thanks. I have selected a B & B header/muffler exhaust system. I am most concerned about the cams and turbo upgrades? I had not planned to change the intercooler as I will be running 1.0 bar, but if an upgraded intercooler will improve engine life and reliability, I would consider it. Any advice is much appreciated?
SCHNELE 08-29-2006 06:22 PM
The intercooler is a must do a search, there are toons of options out there at varied prices.
Ken911 08-29-2006 07:58 PM
and the stock intercooler is a piece of crap. At air temps above 80F it becomes heat soaked and actually adds heat to the turbo discharge.
Porschekid962 08-29-2006 11:25 PM
intercooler is a relatively cheap way to add some power and reliability. on top of that you can put a water fogger, think windshield wiper bottle and nozzles spraying on the intercoolar. say what you will but it helps when temps start to get out of hand, not a long term cure but for short stints it is great, my cousin runs one on his supra, one of the fastest on the west coast to great effect.
SCHNELE 08-30-2006 06:20 AM
forget the water fogger, it is complicated and really a bandaid fix, what you need is a properly sized intercooler for you application, there are a litany of options out there depending on what you want to spend and the quality you expect.
DonE 08-30-2006 06:47 PM
Hmmm... Lots of rally teams would disagree with you.
In fact, my EFI software has a provision for water-cooling the IC by boost, throttle position or RPM.
pushing 930 08-31-2006 06:10 AM
What about cams (SC vs. SC 330 vs. 964) and turbo (K27 7200 vs. K27 S) given my desire for more low/mid range power. As I mentioned before, I have chosen a B and B header exhaust, does it make sense to go with a long neck B and B intercooler to match? Any experience with Blownsix intercoolers?
beepbeep 08-31-2006 08:45 AM
SC cams, bigger intercooler and modern turbo will go far. Porsche crowd defaults to KKK K27 most of times, being conservative and all. But there are better turbochargers nowadays. Garrett GT35BB is very nice piece of equipment and more-or-less state of the art when it comes to reasonably priced road stuff.
RarlyL8 08-31-2006 09:10 AM
The Blownsix intercooler can be had for a good price right now because they are not "out there" yet. A buddy just bought one and should install it soon.
Beep - so if we don't have twin monster turbos hangin' out the back and an intercooler that won't fit within the confines of normal bodywork we are conservative? HA!
Ken911 08-31-2006 11:43 AM
the water fogger doesn't work near as well as direct methanol injection. which costs about the same and uses most of the same parts.
beepbeep 09-01-2006 07:54 AM
Hehe...no, but you must confess that confess that majority of 930 afficionados still buy those K27's for some quite hefty prices, despite being old design.
http://www.pelicanparts.com/support/smileys/drummer.gif
pushing 930 09-03-2006 05:56 AM
There are many versions of the K27 turbo available - given the new SC cams, B & B headers/exhaust and the desire for much better low/mid range performance - any suggestions on the K27?
DonE 09-03-2006 06:13 PM
The stock K27 is not a high performance piece. Even though you state you will not go over 5000 rpm (first time I've ever heard that...), you should upgrade to something more modern and flexible (will accomodate your future mods). If you are a DIY kinda guy, look at the Garrett's. If you are looking for a bolt-on solution, look to Kevin at www.ultimatemotorwerks.com. Bolt-on however, comes at a price.
pushing 930 09-04-2006 05:01 AM
DonE, sorry for the confusion. I definitely go over 5000 rpm.... I just want my useful power band to where the bulk of my driving is. That would be from 2500 - 5000 rpm give or take a little. My preference for a turbo upgrade is a DIY bolt-on solution.
pushing 930 09-08-2006 12:27 PM
Any thoughts on using a stainless steel head gasket on a 79 930 engine?
WydRyd 10-05-2006 09:28 PM
Yes, you can use the C2T 3.3L turbo head gaskets in your engine for even better sealing at higher boost levels (< 1.4bar). If you plan to run any higher boost levels, then you need to look at Flame Rings (Nerosist).
I run C2T head gaskets in my motor, as recommended by Protomotive :cool:
Chuck Jones 10-18-2006 05:22 PM
Pushing 930: I'm chasing the same subject you are...and rather than put the board thru the same questions, I'd like to hear what you've decided and why...but I can't email you privately because you have indicated you don't want to receive email. If you could contact me at fishoncj@aol.com I'd like to discuss what options you are considering, and what you've found so far. Regards, Chuck
BReyes 10-18-2006 08:46 PM
Welcome.
Here is one source: www.goingsuperfast.com (I haven't used these guys (yet-don't know if I will) but found the information helpful while researching turbo upgrades).
It sounds like you are talking about a top end rebuild with while you are there performance upgrades. What has your machinst/builder advised?
Do you have compression/leakdown numbers to justify tearing into it? Is it using too much (>1 qt/1000 mi)oil. Is it leaking oil?. Don't forget the oil lines.
Seems like you take it easy, yet are nearing the the slippery slope.
Have fun. Be safe. And good luck!
Regards,
pushing 930 10-19-2006 07:47 AM
Chuck Jones, I have just emailed a response to you per your request.
pushing 930 10-19-2006 07:59 AM
BReyes, many thanks. My rebuild was preventative maintenance. I am very pleased. The car continues to be a pleasure to drive. The "slope", however, is very slippery.
pdqcarrera 10-20-2006 07:30 PM
Come on Chuck, this thread is going great ... not time to for offline private time! ;-)
My newly acquired '83 930 has a nicely massaged engine with Kokeln intercooler and turbo, RUF intake, B&B headers and exhaust and a few other niceties (inc flame ring heads). It has a USA fuel distributor and lamba which I'm going to change to a Euro/ROW distributor and toss the lamba harness. Supposedly this will help matters and although its not detonating now at 1.0 bar I'd like more insurance without springing for an Andial fuel enrichment rig. I'm amazed at how many mods are available for these engines.
However, for me now, rather than look for more Hp at this point I'm looking to put what I already have to the road more efficiently and so researching G50 trans conversion. Going with a nicely geared 5 speed will make more difference than just about anything else I can do to the engine now.
Cheers!
pushing 930 10-23-2006 12:37 PM
Pdqcarrera, don't discount changing the gearing on the existing 4-speed. Matching your gearing (all four gears) to the engine and the type of driving you do can make all the difference in the drive-ability and enjoyment of your car.
pdqcarrera 10-30-2006 11:17 AM
Yes, I looked into the re-gearing of the 4 speed as an option. The gears and cost of regearing is quite expensive and brings it close enough to the G50 upgrade to make the latter worth the extra difference.
