Rocker and cam oil tube replacement
Is it possible to replace the tube inside of the intake valve cover that squirts oil onto the cam lobes and rockers? A broken rocker hammered it pretty bad, can I just do the tube, or do I need a new cam housing?
Yes, they are removable and replaceable.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
3.4 Bigger is better
You can replace just the tube. You have to drill out the plug to get the tube out. The second picture is how I pulled the plug using a bolt and some different size nuts.
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
