Reusing New Rod Bearings in Diff Rods?
Short Story:
Rebuilding 964 Engine. Reconditioned Stock Rods Installed Rods on Crankshaft with ARP Rod Bolts and New Bearings Turns out the stock rods will not work with new pistons purchased Purchased new rods with an identical big end (stock 964 crankshaft) Can I use the new bearings that were installed on the stock rods? |
rod brgs
Sure, thats not a problem, even if the rods are new be sure to check for clearences, the dimensions on both ends are usually on the small side which tightens up the oil clearence,assume nothing check it or have ot checked before you assemble it.
Mike Bruns JBRacing.com |
| All times are GMT -8. The time now is 04:14 PM. |
