sww914's Avatar
Rocker and cam oil tube replacement
Is it possible to replace the tube inside of the intake valve cover that squirts oil onto the cam lobes and rockers? A broken rocker hammered it pretty bad, can I just do the tube, or do I need a new cam housing?
Old 09-01-2006, 10:50 PM
Jeff Alton's Avatar
Yes, they are removable and replaceable.
Cheers
www.turn3autosport.com
Old 09-01-2006, 11:31 PM
3.4 Bigger is better
88-diamondblue's Avatar
You can replace just the tube. You have to drill out the plug to get the tube out. The second picture is how I pulled the plug using a bolt and some different size nuts.
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 09-01-2006, 11:36 PM
