With the Mahle P+C's, as long as the compression is kept down, as long as the boost was very mild and in check with sufficient IC and fuel, I wouldn't be worried. The other issue with the 100mm bore is that IMHO there isn't sufficient sealing "real estate" to flame ring w/o sacrificing integrity, especially with the Mahle cylinders being cast.
Thanks for the info. I'm currently using an Andial IC, but I'm looking for a DP full bay IC.
Harold |
| All times are GMT -8. The time now is 03:09 PM. |
