-   -   Optimal fan/alternator RPM ? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/303513-optimal-fan-alternator-rpm.html)
YTNUKLR 09-09-2006 11:19 PM
I was looking over the various pulleys and I was wondering what the optimal fan RPM is, for both the 226mm and 245mm housings? For a race motor that will be in the 6.5-8k range all the time.
Grady Clay 09-10-2006 10:09 AM
Scott,
On a cool, foggy day at Laguna Seca, there isn’t an issue. On a typical nice cool day at Willow Springs, say only 103F, you can’t turn the fan fast enough.:D
Since both SCCA and PCA (and most everyone follows those rules to a degree) allow water squirters, the “Rubbermaid Solution”is an inexpensive and very effective solution. For my son’s track car (GT2 914-6) I’m integrating it into the cool suit system. No sense letting the competitors in on the secret.:cool:
http://forums.pelicanparts.com/uploa...1153751331.jpg
To answer your question, I carry the several pulleys, fans & run-in belts and use the combination suitable for the conditions. Think of it as “carb jets for the engine cooling.” :D
Best,
Grady :)
