SS3.2 with stock 3.2 injection?
I am building a 3.2 SS.
I would like to use the stock 3.2 fuel system (including the DME) for ease of use and smog. Is this a viable solution with possibly only a modified chip? I don't have cams selected would 3.2 or 964 cams be appropriate for this, or maybe something differect? Is there anyone with this or similar to this setup? Thanks |
I doubt you could pass smog with a 993 ss cam - check out 3.5 carrera - think he is using a 20/21 grind - that's probably as agressive as you can get using the stock DME.
Steve Wong www.911chips.com could probably give you some really good, CA specific advice |
| All times are GMT -8. The time now is 06:01 PM. |
