Transmission mounting torque specs
I am about to re-attach the transmission back to the engine for install, and I cannot find anywhere in the factory manual what I should torque the 4 mounting nuts and bolt on the case
Could use any help Thanks |
I have the same questions, mine is a 3.2L 1984 Carrera. Any thoughts friends out there?
Thanks, Alex |
tight, but not too tight
Bruce |
That's about where I am at currently. I also put nylock bolts on there that are rated the same as the OEM's were.
Thanks, Alex |
When I can't find a factory recommended torque setting, I go by standard Rockford bolt size recommendations:
http://forums.pelicanparts.com/uploa...1241792749.jpg |
| All times are GMT -8. The time now is 03:49 AM. |
