How do I get the fan off the alt shaft?
I'm wanting to upgrade to this 11blade fan. It's the same diameter as the 5blade so I was hoping to just swap fans.
I have the whole 11blade/alt/housing assembly. Should I keep it together and replace it as a whole unit? or if not can someone tell me how to separate the fan from the alternator shaft? |
http://www.pelicanparts.com/techarticles/911_alt_replace/911_alt_replace.htm
this is in the tech articles on home page you should have no problems following these instructions i used it myself to dissasemble mine today. |
GOT IT!
Thanks |
| All times are GMT -8. The time now is 12:14 AM. |
