1967 911 valve seats
It's time to rebuild my 1967 911 2.0L engine again. This time I think I'd like to install steel valve seats in the heads so I can use unleaded gasoline without mixing in additives every time I fill up. Two related questions: is that still the correct approach to take? Can you recommend a shop that can do that?
One unrelated question: can the rear (front is a better term!) crankshaft main oil seal be replaced without splitting the crankcase? It's been fifteen years since my first rebuild and I forgot how it went on. Thanks a heap, Rick |
Rick:
Any machine shop specializing in 911's can install new, harder seats in your heads that will be compatible with unleaded fuels. (we can do that here in-house, too) Yessir, the main seal behind the flywheel can be replaced without splitting the cases. One must simply be careful about how the new seal is seated.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
