I like Orange
Cookie Porsche's Avatar
Early G50 with 964RS clutch setup
: Also posted on 911 general board...
I am fitting an early G50 (1987 3.2 5-speed)) to a 930 case.
I want to fit the 964RS lightweight clutch setup.
What must I do with the following:
1) The thrust bearings are different?
2) What starter must I use. Looks like the 3.2 G50 doesn't use the same starter as the 964??? Did the 3.2 (G50) have it's own starter?
3) Are the guide tubes the same? The thrust bearing is rather loose on the G50 compared with the 915.
Thanks. Tom
“Rules are meant to be interpreted…”
http://www.cafe9.co.za
Old 10-12-2006, 08:09 AM
