47silver's Avatar
rear wheel bearing cv joint bolts
I am planning to replace both wheel rear bearings and have 2 questions that i could not find answers to in the search.
75 targa (early model).
1. should i replace the cv joint bolts?
2. should i replace the gaskets
Any advice is appreciated.
1975 911S Targa
Silver Anniversary Edition
Old 10-12-2006, 09:38 AM
I would replace the gaskets and if the bolts are in good condition they can be reused. I've found replacements for these at Ace Hardware if you need them. Make sure you get the same quality (grade 8 or whatever).
-Andy
Old 10-12-2006, 05:13 PM
Less brakes, more gas!
euro911sc's Avatar
I bought a whole box of 100 zink plated higher grade bolts from MSC for the same price as I would have gotten them online individually. If you plan on R&R'ing engine/tranny multiple times could be usefull to buy bulk.
Just a thought
Best regards,
Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 10-12-2006, 06:21 PM
